Marvels Mystery Oil - Page 3 - SailNet Community
 6Likes
post #21 of 52 Old 04-29-2013
outbound's Avatar
Re: Marvels Mystery Oil
Jon thanks. very informative. guess we'll stock up on 2% Reg Soy Power or Optilube XPD. Don't know about bypass filtration. Any other source for additional info?
s/v Hippocampus
Outbound 46
outbound is offline
post #22 of 52 Old 04-29-2013
It's the Water and More
Me and Boo's Avatar
Used Marvel Mystery Oil to as the lube for my air tools. Smells good too.
S/V Sisu
1984 Catalina 30 tall rig, bow sprit
Me and Boo is offline
post #23 of 52 Old 04-29-2013
Senior Moment Member
SloopJonB's Avatar
IMHO the best thing you can do is use true synthetic oil. I have seen tests where two identical engines were run side by side on dynos - one on oil and one on synth.
After umpteen hours, only stopping for oil changes - I think it was over 100,000 miles equivalent - they were torn down. The oil engine showed the usual extensive wear you'd find at that point.
The synth. engine was completely clean and all measurements were within original tolerances - essentially NO WEAR.
It's expensive stuff but a classic "pay me now or pay me later" situation.
I've been using it for years in my vehicles and the only downside I've found is a slightly increased tendency to leak - the stuff is so slippery it can creep out where oil stays in.
oldfurr likes this.
SloopJonB is online now
post #24 of 52 Old 04-29-2013
Originally Posted by outbound View Post
...Wonder if cetane boosting would screw up turbo on new engine
I don't think the turbo can know one way or the other. No fuel goes through it.
You also mentioned an infrequent use of biocide. One definitely needs to dose each fill or risk bacteria growing in the tank. There is fuel sold that already has it (Valvtect certified marinas) and you need to be careful not to overdose.
Jeanneau 54DS
Minnewaska is offline
post #25 of 52 Old 04-29-2013
tommays's Avatar
I don't want to bring bad luck to myself BUT I have a 1970 A4 that never had and oil filter let alone good oil for most of its life and has been happy with two valve jobs and some seals and gaskets
It continues to be happy on its now spoiled rotten diet of 15-40 Rotella
At work we have a natural gas 4.3 GM POWERED water chiller (60 hours per week run time) that's gets a Dino oil two times a year and I believe the first block died at 34,000 hours
Are atlas copco screw compressors have always been feed synthetic and while plenty of repairs have happened the screw compressor is still tight At 40000 something
I can't say for sure because it has worn out so many computers the exact hours are a bit of a mystery now
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #26 of 52 Old 04-30-2013
outbound's Avatar
My homeport fuel has biocide in it so tanks always have biocide. Never had issue with growth. Always thought that was enough. Was concerned that with higher cetane power produced at a given rpm would be different and this might effect the amount of air required so effect turbo function. Guess with higher cetane get more rpms with less fuel or fuel to air ratio not effected. Thanks for setting me straight.
s/v Hippocampus
Outbound 46
outbound is offline
post #27 of 52 Old 04-30-2013
A selection of bypass filtration manufacturers includes Amsoil, Gulf Coast Filters, Kleenoil, Racor/Parker Hannifin, and Puradyn...
No need to go with a complete system from any of these, which can run into some serious expense... Pretty easy to cobble together a system using a bypass filter adapter like this:
and a single remote filter... Or, you can go with a system that mounts both the primary and bypass filters remotely, a nice setup if your engine-mounted filter is in an awkward or difficult location to deal with...
JonEisberg is offline
post #28 of 52 Old 04-30-2013
I like those flexible oil lines. Do they come in 1/8 npt for my Atomic 4?
sony2000 is offline
post #29 of 52 Old 04-30-2013
Isn't some form of fuel lubricant needed for A-4's built before lead free gas was introduced and does Marvel Mystery Oil perform that function?
Go here: Find ethanol free gas near you! and see if you can get ethanol free gas in your area.
ccriders is offline
post #30 of 52 Old 04-30-2013
outbound's Avatar
you're the best. Thanks again Jon. Had builder put fitting for filter in return. ?was that a mistake. Would it be better if bypass filter was place just before low pressure pump ?
s/v Hippocampus
Outbound 46
outbound is offline
Mystery - pls help perrygv Sailboat Design and Construction 11 06-29-2015 12:22 AM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
mystery switch teodoro50 General Discussion (sailing related) 45 06-01-2008 12:49 PM
