Marvels Mystery Oil - Page 5 - SailNet Community
 6Likes
post #41 of 52 Old 05-01-2013
Re: Marvels Mystery Oil
Originally Posted by outbound View Post
have filter in return of fuel ( should serve to "polish") but also two filters on oil return ( believe from oil pan and just before pump) . Believe one (first) is 10 micron then (second) is 4 micron . Will be on boat May 21 so will check details. Probably was premature to have troubled you without details in hand. My apologies.
No worries... Sounds like you may already have a bypass system on your engine anyway, on many today they have become standard equipment, though most commonly seen on larger engines from Caterpillar, Detroit, Man, etc...
outbound likes this.
JonEisberg is offline
post #42 of 52 Old 05-01-2013
tommays's Avatar
Originally Posted by travlineasy View Post
I figure it's either guides or rings, but either way, I think I'll construct a kind of a PCV system and send the blowby through the carb's flame arrestor - just to keep it out of the cabin. It's not a lot, but enough to be somewhat annoying.
Cheers,
Gary
It's got the PVC thing already there is a metal tube coming out of the the valve lifter cover and a 90 degree rubber hose connects to it that sits on the flame asrestor on the carb which helps keeps negative crankcase pressure
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #43 of 52 Old 05-01-2013
travlin-easy's Avatar
Yeah, I know, but nothing seems to come out of the hose - just blowby coming out of the oil-fill cap. One day, when I'm not sailing or working, I'm going to take a close look inside the hose and make sure it's not plugged or blocked with some sort of crud.
Gary
travlin-easy is offline
post #44 of 52 Old 05-01-2013
What is "blow by"?
ccriders is offline
post #45 of 52 Old 05-01-2013
Blow by is nothing more than combustion chamber gasses leaking into the crankcase and exhausting through the oil fill cap.
Gary
post #46 of 52 Old 05-23-2013
Administrator
administrator's Avatar
I drink it daily
administrator is offline
post #47 of 52 Old 05-23-2013
krisscross's Avatar
Originally Posted by administrator View Post
I drink it daily
Bender? Is that you, old buddy?
Plato
krisscross is offline
post #48 of 52 Old 05-23-2013
Hey Jeff, C'mon down to the marina Saturday or Sunday and I'll mix you a Green Coconut Margaretta to kill the taste of the Mystery Oil.
Gary
post #49 of 52 Old 05-23-2013
OPossumTX's Avatar
Either MMO or green coconut juice should be good for clearing blockages. Both together might just be too much.
OPossumTX is offline
post #50 of 52 Old 05-23-2013
Administrator
no - he's kbender but he drinks it too!
Mystery - pls help perrygv Sailboat Design and Construction 11 06-29-2015 12:22 AM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 04:26 PM
mystery switch teodoro50 General Discussion (sailing related) 45 06-01-2008 12:49 PM
