Forces on a dockline while docking.... - Page 5 - SailNet Community
 17Likes
post #41 of 47 Old 05-01-2013
pdqaltair's Avatar
Re: Forces on a dockline while docking....
Originally Posted by svHyLyte View Post
... or intuitively understand or appreciate that kinetic energy is equal to the integral of the dot product of the velocity of a body and the differential change of the body's momentum....
Yup, that's one way of making it complicated.
I guess what I'm suggesting, in a way, is a simplification; wouldn't it be nice if ropes were rated for both strength and energy absorption per foot over a few thousand cycles. That matters more, for most applications. It also makes the calculations for dock lines and anchor rodes simpler, since the surge energy is what matters. Two ropes may be of the same strength, but what about fatigue life?
Climbing ropes are rates simply; the number of standard falls survived, with a limit on extension and impact force.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #42 of 47 Old 05-02-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by pdqaltair View Post
...I guess what I'm suggesting, in a way, is a simplification; wouldn't it be nice if ropes were rated for both strength and energy absorption per foot over a few thousand cycles. That matters more, for most applications. It also makes the calculations for dock lines and anchor rodes simpler, since the surge energy is what matters.....
I agree with this sentiment entirely although, frankly, I suspect most non-technical types might not understand the information and thus apply it improperly. Frankly, I would wager many do not understand the significance of the information presented in this thread though it really can be quite important. Knowing how to use a snubbing line/spring to warp a boat around, or stop her, can be the difference between relief and (serious) regret.
FWIW...
svHyLyte is offline
post #43 of 47 Old 05-02-2013
Thanks Courtney.
Knowing the energy absorption of the dockline might be a great idea, but whats the energy absorption of the cleat on the dock? Or the bolts holding the cleat, etc... Seems like using a better docking procedure might be a better idea since you would eliminate many of those variable.
Tempest and svHyLyte like this.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #44 of 47 Old 05-02-2013
Old as Dirt!
svHyLyte's Avatar
Unless I really know a marina's equipment, I will only surge/snub from a piling. I have seen more than one bulkhead/dock cleat ripped out by a snubbing/surge line and with the line under much pressure, they are slung like a rock from a sling-shot.
svHyLyte is offline
post #45 of 47 Old 05-02-2013
Ain't that the truth! I've seen more than one cleat pulled out and a couple launched. Visiting backwater marinas while exploring is a good way to learn alternate docking procedures. Most are not very well equiped with cleats so pilings and other protrusions have to suffice. I really like the looks of that docking thingy for use with a boat hook and after reading this thread will go out and practice other methods besides just going slow.
Kevin
Tallswede is offline
post #46 of 47 Old 05-02-2013
Courtney the Dancer
jrd22's Avatar
40+' sailboat, full throttle in forward, 40 knot tailwind, one line coming tight on a cleat = something is going to give. Unless it's a perfectly straight, unobstructed path from the deck to the dock cleat there's going to be a chafe/break spot, and unless both ends are spliced eyes any knot is going to reduce the breaking strength of the line by about 50%. I suspect that the skipper was allowing the line to slip around the winch to avoid the shock load.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #47 of 47 Old 05-02-2013
Thanks Courtney.
I've also seen old pilings that were previously thought very strong simply break off..
T34C is offline
Forces acting on mast plate Barquito Gear & Maintenance 25 02-22-2013 05:25 PM
Wow, bad dockline setup.... SHNOOL General Discussion (sailing related) 12 08-09-2011 08:15 PM
transient dockline inventory -single vs. double braid? hazmat17 Gear & Maintenance 3 06-04-2010 10:51 AM
Dockline failure from snubber argofred Gear & Maintenance 24 07-24-2009 06:13 PM
Loads & Forces on a Sailboat FishFinder Gear & Maintenance 6 05-01-2009 05:27 PM
