compac 16 - SailNet Community
post #1 of 7 Old 04-29-2013 Thread Starter
compac 16
have to ask something unusual.
Sailed many large boats and am ASA 106.
However, here comes the dumn question. Bought a Compac 16, 1980.
Asked the guy I bought it from , a dealer, where does the boom hook up to the mast? He said it is easy but then mentioned, maybe with a bungie.
Boom has a sliding lockable pin. Cannot find the matching gooseneck on mast. Help!!!
Appreciate and thank anybody that can clear this up.
mariner0822 is offline
post #2 of 7 Old 04-29-2013
krisscross's Avatar
Re: compac 16
See if it goes into the sail track on the mast.
krisscross is offline
post #3 of 7 Old 04-29-2013 Thread Starter
Re: compac 16
yes, it does, but how does it stay in place?
There still is the question how the sliding pin and twist will locate it. thanks. Think there is something missing that fits into the wider slot to lock it. Could be the gooseneck or whatever.
post #4 of 7 Old 05-01-2013
krisscross's Avatar
Re: compac 16
Typically in those smaller boats you first load the main sail into the sail track, following by the boom pin. The pin is held in place by a downhaul line going from the eye on the bottom part of the pin sliding into the sail track. And the sail tension above will not let it come out of the slot (pin needs to stay above the wide slot used for loading it). It is a very simple and effective system.
Plato
post #5 of 7 Old 05-01-2013
krisscross's Avatar
Re: compac 16
One more thing... If you want to drop the main sail and still keep the boom in place, you release the main halyard, pull the boom down so that the pin moves into the lower part of the track, below the wide loading slot, and pull the sail down. If the sail is sticking hard in the track, you need to apply some lubricant to it. I hope this works for you.
Plato
post #6 of 7 Old 05-02-2013
Re: compac 16
I think Krisscross covered most of your options
Downhaull off of gooseneck
or
Pin in the mast. Drill a hole in the mast side to side that goes through the mast track. You can find a quick release pin or a pin and cleavis to fit this hole or better yet buy the pin and drill to its dimensions.
Drop the gooseneck in the track and slide the pin in. When you want to remove the boom, pull the pin and slide out the gooseneck.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #7 of 7 Old 05-03-2013
Smier's Avatar
Re: compac 16
Com-Pac Yacht Owners Association - Index
Very active site with very knowledgable and helpful members, some who have completely torn apart and rebuilt their Compacs! I'll try and remember to scan my owners manual, it has pictures on how to rig everything that will make it easier to understand. These are very simple boats, you will love it.
1980 Compac 16
1983 Starwind 22 w/pop top
Trailer-sailing our way from Pennsylvania to Ontario Canada and soon the Chesapeake Bay!!!
Smier is offline
Tell me about your ComPac I think I want 1 Raggbagger Boat Review and Purchase Forum 6 08-30-2007 10:09 AM
compac 27 mkI alan_21_us Boat Review and Purchase Forum 5 12-02-2006 08:35 PM
Compac 35 JIO Boat Review and Purchase Forum 0 05-14-2002 02:02 PM
HAS ANYONE CRUISED ON A COMPAC 35??? ern-n-jo Cruising & Liveaboard Forum 0 10-08-2001 12:07 PM
