Strange noises from below... - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 04-29-2013
Tartan 37C
T37SOLARE's Avatar
Re: Strange noises from below...
I'll third the cutlass, and throw in an engine alignment/mounts issue as well.
No big deal, just routine maintenance issues.
SOLARE
T-37 #442
T37SOLARE is offline
post #12 of 14 Old 04-29-2013
travlin-easy's Avatar
Ditto on the cutlass bearing.
Gary
travlin-easy is offline
post #13 of 14 Old 04-29-2013
chef2sail's Avatar
If you have a 3gmf like I do there is a spot between 1300-1700 rpm where it isn't as smooth, goes away after you power throught the range.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #14 of 14 Old 05-02-2013
We suggest movement that = more than 2.5% of shaft diameter as a worn bearing and one that should be changed. Different shaft sizes will run different clearances from new and different manufacturers also run different clearances so ideally you should get the spec from the manufacturer.
Kutter is offline
strange Phenomenon that we've seen at sea Boasun Seamanship & Navigation 59 09-24-2015 07:48 AM
Engine noises brak Gear & Maintenance 4 05-20-2009 02:45 PM
Strange Rules gdavids Announcements and Suggestions Box 6 09-14-2007 11:26 AM
Now this is strange. Australia SimonV General Discussion (sailing related) 118 07-07-2007 04:05 AM
Strange Start lefty Racing 3 05-25-2001 06:06 AM
