Strange noises from below... - SailNet Community
 1Likes
post #1 of 14 Old 04-29-2013 Thread Starter
No, I do not need a Rolaids but thanks for asking .
Just bought a 1990 C&C 34+. When motoring at lower rpms, say about 1000-2000, there is this kinda irregular thumping sound which I can feel in my feet and hear. It is not loud and not shaking the boat but still a concern. Just had the boat out for survey and the shaft etc. "looked all right." Boat has a dripless seal which all seems to be in order. Motor mounts seem OK, not a buuch of movement. The sound does seem to be moderated by rpms though. Also, it has started to make a chirping sound, also effected by rpms. At first I thought this could be the fan belt or water pump/alternator but those seem OK.
Could the shaft seal make such noises and vibration? Ideas?
Dave
henrysailor likes this.
Dave Montgomery is offline
post #2 of 14 Old 04-29-2013
krisscross's Avatar
Re: Strange noises from below...
Cam shaft? My truck has that problem. Been like that for the last 30,000 miles.
krisscross is online now
post #3 of 14 Old 04-29-2013
sailvayu's Avatar
Do you have a folding prop? mine used to make noises like that have a fixed one now and no noises.
Capt. Wayne Canning, AMS
sailvayu is offline
post #4 of 14 Old 04-29-2013
Commodore
n8kraft's Avatar
My boat resonates when the engine is running at an idle, 800 to 900 RPM, then everything settles down at higher RPM.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #5 of 14 Old 04-29-2013
SchockT's Avatar
I experienced a chirping noise like you described, and found it was a loose zinc on the propshaft. You may also want to check your cutlass bearing. If you have a folding prop, it may have some slop in the blades, or it may not be opening properly causing an imbalance.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #6 of 14 Old 04-29-2013
BarryL's Avatar
Hey
The thumping sound is a classic symptom of worn cutless bearing.
Good luck
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #7 of 14 Old 04-29-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
After our last haul out for anti fouling in November our girl developed an odd thump thump when in reverse. This with a Flex-o-Fold prop. She was again hauled late March for another reason and while she was out I gave the prop a really good going over to make certain it opened all the way out and had no obstructions. Since going back into the water the noise/vibration has stopped. I am told it could have been cavitation caused by the prop not fully opening (possible something caught up inside) and went away after I had cleaned away the obstruction.
Soooo .... if you have a folding prop maybe same problem. If fixed prop simply ignore everything I have just said.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #8 of 14 Old 04-29-2013
Senior Moment Member
SloopJonB's Avatar
Do you have frisky couples on board when you take the boat out?
SloopJonB is offline
post #9 of 14 Old 04-29-2013
If you can feel it in your feet you most likely have an engine/shaft alignment issue and/or possibly a worn cutlass bearing. I don't no what the chirping is; hamsters?
benesailor is offline
post #10 of 14 Old 04-29-2013
T37Chef's Avatar
cutlass bearing...hopefully you haven't damaged the shaft yet, if so it may need to be replaced as well. Looks like a dive or haulout
Shawn
T37Chef is offline
strange Phenomenon that we've seen at sea Boasun Seamanship & Navigation 59 09-24-2015 07:48 AM
Engine noises brak Gear & Maintenance 4 05-20-2009 02:45 PM
Strange Rules gdavids Announcements and Suggestions Box 6 09-14-2007 11:26 AM
Now this is strange. Australia SimonV General Discussion (sailing related) 118 07-07-2007 04:05 AM
Strange Start lefty Racing 3 05-25-2001 06:06 AM
