Jackline system - Page 3 - SailNet Community
 3Likes
post #21 of 23 Old 05-01-2013
Re: Jackline system
Originally Posted by Joel H. View Post
Jon, I think yours is probably the best advise and approach.
Thanks, but anyone reading this thread should read Rich H's Post #12 again... and then again... That sort of advice is worth more than all the other posts in this thread combined...
It seems though, that I am most vulnerable moving from the cockpit to the shrouds/mast. Using a lanyard long enough to cover the distance between the cockpit anchor and the mast anchor-point concerns me.
Yup, that's pretty much the case on just about every boat out there, that move out of, or back into, the cockpit... One of my biggest gripes about many modern production boats, how poor the ergonomics of that part of the deck can be...
Just so you understand, my main motivation is the 40 deg water that await me if I screw up.
A legitimate fear, to be sure... However, if I ever find myself in the water watching my boat sail off without me, I'd rather the water be 40 degrees, as opposed to that tropical bathwater filled with things that might eat me...(grin)
I probably am over thinking. I come from the climbing world where, except for a "daring" few, the idea is to stay connected at all times.
Also I like the idea of finding ways to use all the neat climbing gear i already have.
Joel H.
You're certainly right to take that approach, of course, it will serve you well...
However, I think probably the greatest risks posed to singlehanders typically come from fatigue or exhaustion, more than anything else... That's why simplicity rules the day with this sort of stuff, in my opinion. Systems that necessitate alertness, deftness, concentration, etc., can so easily come back to bite you in those times when you might be operating at less than 100%...
JonEisberg is offline
post #22 of 23 Old 05-01-2013
Barquito
Barquito's Avatar
Re: Jackline system
If you are single handed, and fall overboard more than a few miles off shore, you will be in trouble. When I am out by myself on the water, I like to think of the boat as being suspended 100' off a concrete parking lot. If you fall over you will die, just like when it is in the water... you will just have a little longer to think about it in the water.
Valiant 32
Barquito is offline
post #23 of 23 Old 05-01-2013
pdqaltair's Avatar
Re: Jackline system
Originally Posted by ccriders View Post
What would be unsatisfactory about 1/2 inch nylon three strand run from port stern cleat through bow cleat to starbard stern cleat? Talking about a 28' boat. Can hook a double teather to port and starbord when in cockpit and unclip one and go forward with the other. The stretch would keep you from breaking your back when falling. Rolling under foot would be minimized as it would lie along the coach house, not in the middle of the side deck.
The only issue I see is unable to clip on before leaving the cabin.
* Nylon is too stretchy for a monohull. With polyester (Say-set or equiv.) it should work.
* Cabin top can work, and yes, the rolling issue goes away. You will have a few step-overs, though. Personally, I like permanent set-ups, as when you need the lines is no time to be setting them.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
12v system and 24v system on 1 boat at same time? BigCatOne Gear & Maintenance 12 07-22-2016 04:46 PM
Help choosing my barrier coat system: Interprotect vs. West System vs. Other? Beersmith Gear & Maintenance 30 02-09-2011 01:10 PM
Jackline: to stern or not to stern dreuge Gear & Maintenance 10 12-24-2009 12:23 PM
Jackline Breaking Strength sailak Gear & Maintenance 5 05-27-2009 11:14 PM
System Three LPU dgr Gear & Maintenance 5 03-17-2009 12:11 AM
