Getting Dinghy on Deck - Page 3 - SailNet Community
 8Likes
post #21 of 25 Old 05-02-2013
Tundra Down
downeast450's Avatar
Re: Getting Dinghy on Deck
I have a gap in my inermediate lifeline I open with pelican hooks. I simply pull the bow thru it, and pull her her up on deck then turn her around and tie her down . Takes seconds. Same for launching
Brent,
Makes sense to me. I replaced my lifelines with Amsteel last year. Time to add a pelican hook forward.
Thanks for pointing out the obvious. Not obvious to me!
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #22 of 25 Old 05-02-2013
formerly posting as eryka
wingNwing's Avatar
We use the spin halyard and the anchor windlass, and keep the dink on deck any time we're going more than an hour from one anchorage to the next in calm water. Dragging the dink costs us the better part of a knot of speed. Connect the halyard to the dinghy bow, then hoist. Put the transom down near the mast, then ease the bow forward and down. Currently we have an inflatable but we dealt with it the same way with our Walker Bay 8.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #23 of 25 Old 05-02-2013
I wouldn't suggest that you cross the ocean with the dinghy on the davits in any case as it could get pooped to easily.
Well, not necessarily... (grin)
Guess nobody ever told this guy that the Caribbean 1500 is likely to be a ride on port tack most of the way... In which case, he probably should should have mounted the bow facing the other way... If that sucker starts collecting water from squalls and whatnot, you'd want to have the transom with the drain plug open on the low side, seems to me... That thing could catch an awful lot of water, before it would start draining while sailing on port tack - and given the extreme height of that boom, doesn't look like it would take too much breeze to lay that thing over on her ear...
Hell, I'm surprised he doesn't have the engine up there, as well...
Or, perhaps I didn't notice, and he had it stowed at the freakin' masthead...
Have I mentioned that I hate tenders on davits, or gear stowed up high, in a seaway? (grin)
JonEisberg is offline
post #24 of 25 Old 05-02-2013
Jeez, some people will do anything to avoid having to move the stern light when they add davits.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #25 of 25 Old 05-02-2013
bigdogandy's Avatar
Dock
Originally Posted by MarioG View Post
I use the main halyard to bring our Walker bay 8' dinghy. I use the boat pole to hold it off the life lines untill its high enough to bring it on. a wench and cleat on the mast helps haul and lock it when I need to move it in place.
I have an 8' Walker Bay and an 8' inflatable, and use the same method to lift and place them on the foredeck (not at the same time, of course!). The foam insulation Faster mentioned is great for protecting the dinghy and the hull and deck of my boat from scratches.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
Tags
deck , dinghy , halyard , heave , hoist
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-25-2012 11:10 PM
PSC 31 Measurement for Dinghy on Deck djmarchand Pacific Seacraft 5 04-23-2008 09:58 PM
Split deck cap and leaking hull/deck joint alaskaboy Gear & Maintenance 2 01-04-2008 09:25 PM
through deck coaxial cable-what wonderful suprises await me, my deck and my drill? bwu Catalina 1 11-20-2006 01:06 PM
Dinghy Launch & Retrieval (Deck) nalani Cruising & Liveaboard Forum 0 11-27-2001 05:49 AM
