how to make a marconi sail - Page 2 - SailNet Community
post #11 of 12 Old 05-04-2013
Re: how to make a marconi sail
Hey my first post so go easy on me.
The sail has to look like an airplane wing if you want marconi effect.
You need lateral resistance also preferably in the shape of a foil, to get the same kind of lift under water. Sails up top high pressure on the front side, low on the loured side, therefor fast flow adhering to the back side of the sail, causing marconi basically sucking forward and wind ward. Under water with pressure on the leeward and low on windward. Same but opposite. Again sucking you forward and if well built to windward. So basically you have an airplane wing turned on it side on the top of the boat, and one at the bottom of the boat. (airplane on it's side) Thrust is caused by the pressure and the lateral resistance, that's the fuel. the "lift" is cause by the marconni effect.
Basically I think of it as an airplane turned 90 degrees
tm
tommad is offline
post #12 of 12 Old 05-05-2013
What he needs for his kayak are called "Leeboards" and consist of rotatable daggerboards on either side of the hull. They rotate up or down. Down for sailing to prevent the boat going sideways (making leeway) and up for shallow water. They can be on a common axle running across the deck of the kayak and should project about a foot below the bottom of the kayak.
What do you use as a rudder?
Leeboards are a common feature on some shoal draft boats (check out the designs of Michalak and Bolger)
Frogwatch is offline
How to make my own sail? MattMcc804 Learning to Sail 9 05-06-2013 11:18 PM
What can I EASILY make out of an old sail vtsailguy Gear & Maintenance 26 02-19-2013 09:41 AM
make a gale sail SailingChance General Discussion (sailing related) 18 01-23-2013 02:54 PM
converting marconi to gaff rig BenMP Gear & Maintenance 12 11-29-2010 12:11 AM
gaff rigged? Full Battened Marconi? jbarros Boat Review and Purchase Forum 11 08-06-2003 11:03 AM
