First centerboard vs. rock experience - SailNet Community
post #1 of 12 Old 05-05-2013 Thread Starter
CaribDream's Avatar
3rd time out with my brand new boat (American 14.6)... On a reach moving along nicely and... BANG. Guys at a local club said they think a danger buoy drifted/moved. Anyway, I'm pretty sick about it Looks like it's just the gel coat at the tip of the board, but none the less a big disappointment. The affected area is about 3/4 of an inch square. Less than 1/2 inch of gel coat is missing, and the rest of the effected area is cracked.
What's the best way to fix this? Is it something I need to deal with immediately before taking the boat out again or can it wait a while?
Go sailing now my brother,
It's later than you think.
CaribDream is offline
post #2 of 12 Old 05-05-2013
Re: First centerboard vs. rock experience
Welcome to the joys of boating .. uh .. er .. um .. maintenance. An easy fix, fortunately. Years from now you'll look back on this repair and wish they all were so easy. And yes, you likely want to tend to this repair soon as the board's core may swell up and get stuck in its trunk if left unrepaired.
You want to grind back the damaged area to the undamaged surface, opening up the cracks a bit. Wipe down the area vigorously with acetone; by the time you've mixed up some epoxy without filler the acetone will have evaporated. This is a small area, so apply the wet epoxy with a toothbrush or one inch paint brush. Then add a thickener/filler to the remaining epoxy you've mixed and apply to the wet epoxied surface. Ever done a spackle job on drywall? Sort of similar. You want to build up the area a bit beyond what you originally had before. Let it cure at least a dozen hours.
Upon your return, the epoxy should be hard. Sand smooth back to the shape you had before the impact, reinstall the board, and go sailing.
Michael K is offline
post #3 of 12 Old 05-05-2013
Joel H. is offline
post #4 of 12 Old 05-05-2013
krisscross's Avatar
Carib, you should also check the centerboard box to make sure there is no damage there. Hard grounding puts a lot of stress on the box. You do not want a leak there. Usually fixing it is no big deal but it needs to be done sooner rather than later.
A boat without dings is a boat without character!
Plato
krisscross is online now
post #5 of 12 Old 05-05-2013
Tartan 27' owner
CalebD's Avatar
I can't add much to Michael K.'s post but I have just been doing some fairly major fiberglass deck work on my old, dinged up boat.
For a repair of such a small area you may or may not be adding fiberglass cloth. The silica thickener agent should be enough to repair the ding.
I successfully used some pieces of flashing (flat metal that is used on house roofs etc) to make a mold for a flat surface I was filling with epoxy. Making a mold that conforms to the shape of your repair should save on the amount of sanding needed to be done once the epoxy cures (1 day).
Someone else suggested they used tin foil as a release film with epoxy. I'd probably opt for the heavy duty foil over the regular stuff.
Also, some plastics, like the stuff they use to make gallon containers of milk etc., do not adhere well to epoxy and can be used to make pieces of a mold.
Welcome to the wonderful world of ... boating.
Everybody has one:
CalebD is offline
post #6 of 12 Old 05-06-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
making me glad all I ever had to deal with was mud... lots and lots and lots of mud
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 12 Old 05-06-2013 Thread Starter
CaribDream's Avatar
Thanks for this. Is there a type/brand of epoxy to look for? Do I get it at a hardware store? Now the trick will be finding time - my worst enemy. I work 15 hours a day M-F and will be out of town for the next 3 weekends... Didn't take me long to mess up my relaxation for the few short hours of free time I have on weekends.
post #8 of 12 Old 05-06-2013
Blue Horizons
Harborless's Avatar
I remember when I paid a guy to clean my bottom. He came up and said "Theres the problem, your centerboards been snapped in two!"
$1000 dollars later I have a very robust new centerboard.
Harborless is offline
post #9 of 12 Old 05-06-2013
Tartan 27' owner
CalebD's Avatar
Carib,
It is probably best to use a decent marine epoxy, not just any epoxy. There are a number of epoxies available: MAS, System 3, West System ...
For a small repair like what you are looking at I'd suggest getting a small starter kit like this one: West System Handy Repair Pack
or this slightly larger pack: West System Maxi Repair Pack
Some of the local hardware stores near me have begun to carry the West System products, so you might find these kits nearby.
West System also has a good diy instruction web page:
WEST SYSTEM | Use Guides
Everybody has one:
CalebD is offline
post #10 of 12 Old 05-06-2013
Mechsmith
After sailing , fishing, and gunkholing in SW FL and the keys for several years I put a 1" X 1/4" stainless steel "sled runner" on my swing keel. Still looked pretty good after a couple years.
Seafarer 29 KCB
Mechsmith is offline
Rock hall? AirborneSF Chesapeake Bay 15 02-04-2013 06:54 PM
Kimberley Rock Art JackandJude Cruising Videos 8 11-28-2012 04:42 AM
Centerboard position - keel/centerboard Tartan 37 upwind cspear Racing 14 07-02-2012 12:31 PM
So I hit this rock... again... and again deckhanddave General Discussion (sailing related) 4 11-21-2006 08:26 PM
Rock Hall, MD for the 4th SailinJay General Discussion (sailing related) 1 06-30-2004 01:10 PM
