Blogs
User Name
Old 06-16-2004
sadie14 sadie14 is offline
sadie14 is on a distinguished road
Awning Poles
Any good ideas for collapsible awning poles that are not as expensive as telescoping poles? We''ve been using PVC, cut in 3 pieces, but in high winds, they come apart. (About 10'' wide)
Old 06-16-2004
kokopelli9 kokopelli9 is offline
kokopelli9 is an unknown quantity at this point
Awning Poles
Sadie14,
Don''t think these will be sturdy enough to replace what you having been using but they may come in handy somehow...I used kite spar for support in my cockpit canopy...it is very strong, yet flexible enough to bend with the wind a little rather than break. You can cut it in the lengths you need and there are little connectors to join pieces.
bobbi
s/v Kokopelli
Old 06-16-2004
Awning Poles
Sorry, I probably should explain the the PVC is not breaking, just the connection points are popping, so the poles are no longer connected and the awning is not supported.
I don''t know what a kite spar is. Can you explain further, please.
Old 06-16-2004
Awning Poles
Kite spars are the "backbone" in kites...the big, expensive stunt kites. They are like PVC pipe except solid, not hollow...and usually they are small in diameter...like maybe 1/2 inch or so. I used them in the "roof" of my canopy and they worked quite well.
bobbi
Old 06-17-2004
maestro maestro is offline
maestro is on a distinguished road
Awning Poles
how about tent support rods?? you know, the kind that folds up into 2 ft. lenghts and have the elastic line running through the middle?? Would that work?
Old 06-17-2004
dirtchickn dirtchickn is offline
dirtchickn is on a distinguished road
Awning Poles
Try drilling a few holes in the PVC and connectors and running a few bolts and wing nuts to hols it all together. Quick and easy assembly. Just remeber there may be more chafe near the bolts...
Old 06-22-2004
terry-gufshoz terry-gufshoz is offline
terry-gufshoz is on a distinguished road
Awning Poles
Just another thought. Why not get some stock bungee cord and thread it through the PVC support poles and connecters ? This would keep them together and when you''re not using them allow you to fold them like the collapsable tent supports.
Terry
Display Modes
vB code is On
homemade MOB poles? e31 Gear & Maintenance 4 03-30-2004 04:27 AM
Whisker Poles RichardElliott Gear & Maintenance 1 02-11-2003 10:27 AM
where to get cheap whisker poles? ern-n-jo Gear & Maintenance 5 09-21-2002 02:28 PM
used whisker poles chris1f Gear & Maintenance 1 06-15-2002 01:18 PM
Frozen whisker poles bsfree Gear & Maintenance 3 05-17-2002 08:00 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
