Another (stupid?) outboard motor question - Page 2 - SailNet Community
 8Likes
post #11 of 20 Old 05-08-2013
krisscross's Avatar
Re: Another (stupid?) outboard motor question
Most people operate the choke in fully open or fully closed position. That is not the best practice. A lot of times when the weather is fairly warm (mid 50's) half choke is the best way to go when starting. If you use too much choke you will likely flood the motor and have a hard time starting it. Find the right amount of choke for your motor and really listen to how it reacts.
Plato
krisscross is offline
post #12 of 20 Old 05-08-2013
Captain Obvious
Sal Paradise's Avatar
Originally Posted by chucklesR View Post
IMHO 'cold' means cold air, not cold engine. I try for a start without choke, then choke if it doesn't start.
Actually the fuel in the air condenses against the cold cylinder walls and this results in a very lean air -fuel mixture.
So we richen it up with the choke.
Sal Paradise is online now
post #13 of 20 Old 05-08-2013
Originally Posted by Sal Paradise View Post
Actually the fuel in the air condensates against the cold cylinder walls and this results in a very lean air -fuel mixture.
That and the colder air is denser so you need more fuel to achieve proper stoichiometric fuel/air ratio.
Racecase is offline
post #14 of 20 Old 05-08-2013
outbound's Avatar
If this is a change in behavior ?Is it worthwhile to take the carb down and make sure it doesn't have junk in the holes or is not tuned correctly.?Make sure your gas is ok. Last summer had trouble with an old Yama ( early 80's). Was filling it from the same gas container that sat for awhile. Needed choke to start everytime. Ran through that container and all was peace in the valley.
s/v Hippocampus
Outbound 46
outbound is offline
post #15 of 20 Old 05-09-2013
Dirty spark plugs change outboard behavior. I change them out every couple of years and clean them annually.
As a cheat, I will also occasionally spray ValvTects Marine Motor de-Carb through the intake. Smokes like a forest fire, while you're doing it, and its not just a dainty spray and you're done. You spray the whole can. I think it works, makes me feel like I did something anyway.
Jeanneau 54DS
Minnewaska is offline
post #16 of 20 Old 05-09-2013
I have been using this:
B-12 ChemtoolŪ Carburetor, Fuel System and Injector Cleaner | Berryman Products
for 30 years in anything that burns gasoline with no fuel related problems.
Paul T
dabnis is offline
post #17 of 20 Old 05-09-2013
Puget Sound Pounder
kellysails's Avatar
Originally Posted by blutoyz View Post
To the OP
You won't find a procedure...every engine has a "personality". Experiment with different conditions and in a month you will know when it wants choke.
++1 on this. So extremely true.
kellysails is offline
post #18 of 20 Old 05-09-2013
Another thought.
If you find you need any choke to start a warm engine, something is wrong.
Jeanneau 54DS
post #19 of 20 Old 05-09-2013
...and don't run Ethanol gas in a 2-stroke. Inconsistant problems will manifest in ways that will have you chasing every possible engine problem you can think of, only to discover that your gas is the culprit. People have various levels of success with Ethanol gas by using additives. I learned the hard way that it's just easier to avoid Ethanol.
ShoalFinder is offline
post #20 of 20 Old 05-10-2013
blutoyz's Avatar
Another thought.
Good point here^^
blutoyz is offline
yamaha outboard question with video. t9.9elhp motor Incantation Gear & Maintenance 5 10-27-2010 01:06 PM
Stupid radio, stupid question. (stupid owner?) jjns Gear & Maintenance 8 06-22-2009 06:08 AM
Small outboard motor question for the maintenance experts. Northbeach Gear & Maintenance 7 07-19-2008 12:48 AM
outboard motor newbie question calamitas Gear & Maintenance 5 06-08-2007 08:31 AM
No clue re: outboard motor!? Saltwater question! Cony Gear & Maintenance 7 03-13-2004 06:22 PM
