Another (stupid?) outboard motor question - SailNet Community
 8Likes
post #1 of 20 Old 05-08-2013 Thread Starter
My Mercury 4hp 4 stroke's manual states that you should use the choke when starting the engine when it is cold.
I took this to mean when the engine is being started for the first time in a while (several hours to days, weeks etc..).
But now that warm weather is here, it seems to not start with choke engaged. I have to wait, disengage choke and put throttle on "restart" instead of "start".
Is this because they mean a cold engine is really a cold engine like back in December? And an engine in the sunlight on an 80 degree afternoon is not cold? Even if it hasn't been started yet today?
Thanks!
matthewwhill is offline
post #2 of 20 Old 05-08-2013
no longer reading SailNet
Alex W's Avatar
Re: Another (stupid?) outboard motor question
We only use the choke on the coldest days of the year (like below 40 or 45 degrees). The engine starts right up without it even if it is 50 degrees out.
I don't know if this is right, it is just what works for us.
Alex W is offline
post #3 of 20 Old 05-08-2013
Shoundnt really need to choke it in 80 degree weather, If my 1972 johnson sits for a few days I need to but just for a second while turning it over, after that its good for a few more days
MattMcc804 is offline
post #4 of 20 Old 05-08-2013
My Honda 5-hp manual says to use the choke only when outside temperatures are below 68-F.
bnaylor is offline
post #5 of 20 Old 05-08-2013
Captain Obvious
Sal Paradise's Avatar
It really depends on your individual motor. I put my Merc 4 HP 4 stroke on half choke and it starts first pull.
Sal Paradise is offline
post #6 of 20 Old 05-08-2013
chucklesR's Avatar
IMHO 'cold' means cold air, not cold engine. I try for a start without choke, then choke if it doesn't start.
chucklesR is offline
post #7 of 20 Old 05-08-2013
I give mine a stern look, make a few intimidating comments about being the only thing between it and the junk pile and then pull the cord/turn the key. It usually cooperates.
jeffzee, davidpm, bljones and 1 others like this.
Jeanneau 54DS
Minnewaska is offline
post #8 of 20 Old 05-08-2013
You aren't going to hurt the engine by using, or not using, the choke. If it starts and runs, you didn't need the choke. It if won't start, choke it. All the choke is doing is regulating the fuel / air mixture. Your car does this automatically through a combination of sensors in the air intake, not to mention your car also has the benefit of electronic fuel injection which allows more control than a carburetor does.
Like Sal says, every engine is a little different- especially when they get a little age on them. Just like a woman, you learn what she needs to be happy and you give it to her. You usually measure success by the feedback from the fuss-o-meter.
I have a Nissan 5hp that needs half choke whenever I go to start it, even if it's 95 degrees outside. There isn't much adjustment to the carb, so it's just as easy to use the choke to give the girl what she wants. .
It starts on the first pull unless it has sat for a few weeks, in which case it needs a few pulls on full choke, then a few with no choke, then it talks a little smack which tells me she's ready for half choke. Then she's up and running and stops her griping.
c. breeze and Lateen Luffer like this.
ShoalFinder is offline
post #9 of 20 Old 05-08-2013
blutoyz's Avatar
Oh...that IS a cold start right there
bljones likes this.
blutoyz is offline
post #10 of 20 Old 05-08-2013
blutoyz's Avatar
To the OP
You won't find a procedure...every engine has a "personality". Experiment with different conditions and in a month you will know when it wants choke.
FSMike likes this.
blutoyz is offline
yamaha outboard question with video. t9.9elhp motor Incantation Gear & Maintenance 5 10-27-2010 01:06 PM
Stupid radio, stupid question. (stupid owner?) jjns Gear & Maintenance 8 06-22-2009 06:08 AM
Small outboard motor question for the maintenance experts. Northbeach Gear & Maintenance 7 07-19-2008 12:48 AM
outboard motor newbie question calamitas Gear & Maintenance 5 06-08-2007 08:31 AM
No clue re: outboard motor!? Saltwater question! Cony Gear & Maintenance 7 03-13-2004 06:22 PM
