Mooring ball too close? - SailNet Community
 4Likes
post #1 of 14 Old 05-13-2013 Thread Starter
Our boat was launched on Saturday and when we went to see it yesterday we noticed that the stern is rather close to the mooring ball behind us (I'd say our stern is within 6 feet). It's close enough that we couldn't tie our dinghy off of the stern. The marina said the ball behind us is unassigned so we could use an extra long painter to tie the dinghy off, but I was thinking of asking to be reassigned to a different mooring ball.
Am I worrying over nothing? This is our first boat, so I recognize that's quite possible! Any thoughts would be appreciated.
Thanks!
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #2 of 14 Old 05-13-2013
blutoyz's Avatar
Re: Mooring ball too close?
The marina did not assign it so if they do it is up to them to assigne you a new mooring with proper swing.
zeehag likes this.
blutoyz is offline
post #3 of 14 Old 05-13-2013
jjablonowski's Avatar
Many, if not most, mooring systems use a length of heavy chain attached to the mushroom or block, the end of which is then connected to the line that goes up to the mooring ball. The chain lies on the bottom, and if it is pointed in the direction of your mooring, it effectively moves the ground zero for its ball closer to your boat. (But once another boat is tied to that mooring, that boat's mass is enough to drag the chain on the bottom away from your mooring.)
This happened to me, and when the mooring service came to fix it, the guy just picked up the offending ball and dragged it away from my mooring. Problem solved.
Minnewaska and capta like this.
Joe - s/v Assignment, Catalina 320
jjablonowski is offline
post #4 of 14 Old 05-13-2013
snake charmer, cat herder
zeehag's Avatar
mt formosa was assigned to a ball with a power boat next to it---of course they hit--and all damages were to my formosa, before i bought her....do move and prevent this from happening to you..my po was a boat virgin, and didnt know any better--i took pix and sent to mooring co, but they did nothing about the mayhem insofar as relocation of the offending power boat, which was in with deep keeled formosa type boats--between a ct 41 and a formosa 41--only hit mine, was decent distance from the other ct....get to a place with the correct amount of swing for each involved boat. 6 ft doesnt cut it.
formosa 41, cruising tropics
zeehag is offline
post #5 of 14 Old 05-13-2013 Thread Starter
There seems to be plenty of room to swing around. It was quite windy yesterday and we were turning quite a bit. It's just that our closest point to the ball behind us is around six feet or so. But that ball is going to remain unassigned. Maybe I'm obsessing over nothing. Or not. I don't know. Sigh.
wdwright1967 likes this.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #6 of 14 Old 05-13-2013
blutoyz's Avatar
No reason to stress if it remains vacant
blutoyz is offline
post #7 of 14 Old 05-13-2013
Owned by Velcro
Ferretchaser's Avatar
Just use the dink to pull the ball away a bit. The chain should them keep it put with no boat hanging on it.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #8 of 14 Old 05-13-2013
Maine Dub
34crealock's Avatar
As joe said if it has excess chain you might be able to yank it back away with your dink. Power boats and sailboats usually don't swing at anchor together. They will each react to wind and current in different ways. A deep keel sailboat should moor near other deep keel sailboats. When I pickup a mooring I generally back down on it to stretch it out and to make sure it is secure.
34crealock is offline
post #9 of 14 Old 05-13-2013
denverd0n's Avatar
Please don't take offense, but just to be sure...
You don't have your boat excessively far away from your own mooring, do you? I have seen boats with 20' or 30' of line between their boat and the mooring pendant. No need for that much.
denverd0n is offline
post #10 of 14 Old 05-13-2013 Thread Starter
No offense taken it all.
I'm not sure how many feet of line it's on (it's just the line that is supplied with the mooring), but it definitely doesn't look like 20-30 feet. I'll take a look at that when we're back there on Friday though.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
The physics of a mooring ball... MedSailor General Discussion (sailing related) 11 04-01-2013 10:59 AM
Can't close ball valve on thru-hull thereIwas Gear & Maintenance 36 12-10-2010 03:27 PM
Mooring Ball Covers? CBinRI Gear & Maintenance 10 05-20-2009 05:36 PM
Mooring ball heads up!! Maine Sail Gear & Maintenance 15 06-13-2008 08:52 PM
marking a mooring ball... kokopelli9 Gear & Maintenance 9 02-29-2008 03:03 PM
