Checklist - SailNet Community
 2Likes
  • 1 Post By Ferretchaser
  • 1 Post By jephotog
post #1 of 9 Old 05-13-2013 Thread Starter
Checklist
I am starting to charter some boats, and have created a checklist to cover all the steps. Most of my crew have been inexperienced sailors so need to be thorough. Any suggestions things I could add, way to improve this?
Pre Planning
Day before
Charge AA batteries
Float Plan
Check Weather
Pack Bags
Appropriate Clothing
Flashlights
GPS
Navigation Kit
Cameras
Day of (at home):
Confirm weather
At Boat
Open all hatches to ventilate.
Check Engine
Oil Level
Fuel Separator/Filters
Closed Loop level
Raw water strainer
Belt tension
Leaks
Check Tankage
Fuel Level
Fresh Water Level
Holding Tank Level
Bilge Area
Dry
Test Pump
Batteries
Water level
Secure.
Test Main Switch and condition of each battery charge
Through Hullls
Locate all
Inspect Open or close
Wood Bungs
Locate the Following
Boat Docs
Registration
Appropriate signage
Garbage
Oil
PFDs
One per crew (I,II or III)
IV for cockpit
Fire Extinguishers
Check charge and date
<26 1-B-I
26-40 2-B-I or one B-II
>40 3-B-I or (1-B-II & 1-B-1)
USCG kit
Signal Device
Horn
Bell if over 40
Flares 3-day 3-Night
GPS/Navigation
Light
Boat Hook
Emergency Tiller
Anchor readiness
Owners Manual
MSD
Crew Brief
Non-Swimmers?
Seasickness?
PFDs
Going forward
MOB
Radio
GPS
Fire Extinguishers
MSD
Water Conservation
Electricity Conservation
Lines in the water
Boat terminology
Proper Watch
a. Relative bearing
b. Kelp
c. Right of Way
See something say something
Departure Preperation
Winch Handle
Remove Sail Covers
Stopper Knots.
Remove Shore Power
Note Wind/Plan departure
Departure Brief
Assignments
Concerns
Engine Starting
Ventilate Cabin
Batteries to all
Blower
Glow Plug
Neutral
Throttle
Start
Ensure water in Exhaust
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #2 of 9 Old 05-13-2013
The most female moderator
Donna_F's Avatar
Dock
Re: Checklist
This is just me, but if I had inexperienced crew, I would try not to overwhelm them with EVERYTHING that should be done on the boat, just what I am expecting of them. Even then, for the first few times I'd keep my expectations low so that they get to enjoy the sailing part. If I received that list before I started sailing, I'd wonder where the fun was wedged in.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 9 Old 05-13-2013
Owned by Velcro
Ferretchaser's Avatar
Re: Checklist
Check beer level in cooler
Minnesail likes this.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #4 of 9 Old 05-13-2013 Thread Starter
Re: Checklist
Except for the crew briefing part this list is for me only to make sure I do not forget anything.
Jordan
Oceanside CA
jephotog is offline
post #5 of 9 Old 05-13-2013 Thread Starter
Re: Checklist
I am an avid homebrewer. I have not put that on the checklist because I would never forget an adequate supply of beer. The list is more so I don't forget my foulies while focusing on trying to figure out how to get a keg on board.
Ferretchaser likes this.
Jordan
Oceanside CA
jephotog is offline
post #6 of 9 Old 05-13-2013
Donna_F's Avatar
Dock
Re: Checklist
List for only you makes more sense. I start checking the weather three days before. Gives me a feeling for what may be blowing my way (depending on conditions) in plenty of time to come up with Plans B and C if I have to and time to alert any guests that things may not work out.
I would also add a check of rigging hardware. When we chartered I did a once over on the hardware I could see and had them replace a couple of things that looked bad.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #7 of 9 Old 05-13-2013
Donna_F's Avatar
Dock
Re: Checklist
And another weather check under the "Departure Prep" heading.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #8 of 9 Old 05-13-2013
no longer reading SailNet
Alex W's Avatar
Re: Checklist
Departure Check should including turning on boat electronics (and handheld ones, if any). I often forget about this until we are under way.
Alex W is offline
post #9 of 9 Old 05-13-2013 Thread Starter
Re: Checklist
Do your remember the movie L.A. story?
I check the weather often usually a non-factor. I was scheduled to sail last Wednesday with someone in a group I belong to. The boat owner canceled on Monday because of a 10% chance of rain. It ended up being "Sunny and Beautiful" as in the movie.
Check Alex on the radios. I will also add electronics panel familiarization.
Jordan
Oceanside CA
jephotog is offline
Pre sail checklist Gregrosine General Discussion (sailing related) 16 10-30-2015 12:07 AM
Anyone use a checklist boating2go General Discussion (sailing related) 20 08-20-2012 04:48 PM
Everyone...Share your checklist T37Chef General Discussion (sailing related) 11 06-26-2011 11:43 PM
