Who sells marine plywood? - Page 2 - SailNet Community
 9Likes
post #11 of 47 Old 05-16-2013
Re: Who sells marine plywood?
For inside the boat not exposed to water, a both-sides good hardwood plywood saturated with a penetrating epoxy would be more than good enough. 3/4" plywood is better than 1/2".
This may also be good for the transom work but double 3/4" and add a few layers of saturated fiberglass fabric.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #12 of 47 Old 05-16-2013
Can anyone give an example of when marine grade NEEDS to be used instead of pressure treated? When is it worth it?
1982 Starwind 22 Mk II | Lake Lemon, Indiana |
(Previously posting as LemonHead)
CarpeAquam is offline
post #13 of 47 Old 05-16-2013
T37Chef's Avatar
Originally Posted by jimgo View Post
Chef,
I need a roughly 3'x 6' section (still need to measure) for the Allmand's shelf. The Albacore is about a 4' x 2'.
I would have to measure but I think I have a piece that would fit your 4'x2' section but I don't have a piece large enough for the 6' section, so you would have to buy a 4'x8' sheet anyway.
I know Exotic typically carries it in stock but not sure if that is convenient for you?
I would probably want to use Marine Plywood for the jobs you want to do, but I suppose you could get by with the other suggestions, maybe pose your question to the Wooden Boat Forum? LOL
Shawn
T37Chef is offline
post #14 of 47 Old 05-16-2013
Jim,
Lowe's, Menard's, and Home Depot will all special order it for you, however it is expensive. You really only need marine grade for boat hulls where it's important not to have voids in the plywood interior. Everything else you could use a good grade of exterior plywood which is made with "waterproof" glues but does have some voids on the interior. As long as everything is water-tight, which you would want regardless of which grade plywood you use, you should be good to go for both your projects.
Everyone has two cents, these were mine :-)
Frank
1982 S2 9.2A
bljones likes this.
fharbison is offline
post #15 of 47 Old 05-16-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Thanks everyone!
Shawn, I think you're going to be far enough away that it won't really be cost effective for me to buy the small piece from you. If you had both, I'd be game. It would be nice to meet you!
Thanks again for the quick and helpful replies!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #16 of 47 Old 05-16-2013
Learning the HARD way...
eherlihy's Avatar
One more source of marine and exotic plywoods, and they will ship, is Boulter Plywood in Sommerville MA. BoulterPlywood.com....
Marine grade plywood uses waterproof and boilproof adhesive, and has NO VOIDS (at all).
eherlihy is online now
post #17 of 47 Old 05-16-2013
Another way to find wood suppliers (plywood or hardwood) is using woodfinder.
MikoBee is offline
post #18 of 47 Old 05-16-2013
bljones's Avatar
Regarding pressure treated: NO.
It doesn't like varnish and it doesn't like epoxy.
A good exterior grade ply, sealed with epoxy is more than adequate for backing plates and core reconstruction. for NON-STRUCTURAL below-decks use, a sheet of cabinet grade ply sealed with epoxy is fine.
It's 5 o'clock somewhere:
bljones is offline
post #19 of 47 Old 05-16-2013
BluemanSailor's Avatar
Jim, I see that your in PA. Check with the local lumber yards, not Lowes or Homedepot. My local yard in Hatboro actually had some in stock, I needed 3/4" and 1/4" they had them. Older stock that they were not going to replenish.
Also Delaware Supply Co.in Boothwyn, has a ton of hardwoods and plywood, just off of 95 near the Delaware border. Have a couple of wooden boatbuilders I know who buy their lumber there.
Roland
Sailor - kayaker - woodturner - Photographer.
New boat sailblog -
BluemanSailor is offline
post #20 of 47 Old 05-16-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
BlueMan, I'm not that far from you (near Lansdale). Hatboro is an easy drive for me. Where did you find them? I can always call and see if they still have any. Otherwise, I can try Delaware Supply, but that's a bit of a hike.
Thanks for the tips!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Marine plywood gg30citation Gear & Maintenance 6 01-26-2008 10:23 AM
Marine plywood gg30citation Gear & Maintenance 2 01-25-2008 10:32 PM
Hunt for Marine Plywood landlockvasailor Gear & Maintenance 11 08-30-2007 06:01 AM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 12:12 AM
MARINE PLYWOOD drynoc Gear & Maintenance 3 01-30-2004 08:14 AM
