I can't heave to - Page 3 - SailNet Community
 1Likes
post #21 of 28 Old 05-18-2013
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Alternate with beer.....
oysterman23 is offline
post #22 of 28 Old 05-18-2013
Re: I can't heave to
I agree that you're going to want to find the balance to be able to heave-to in all conditions
But, if the wind is typically only 5 kn. or less, and you have room with no one near you, just head up ease the sails a bit put a bungy cord on the tiller and do what you need to do.. how much trouble can you get into going 2 kn.
tempest is offline
post #23 of 28 Old 07-05-2013
Garret01's Avatar
As I post this, I will give notice that I am brand spankin new to sailing.
When heaving to, should you end up at the "in irons" position or does it matter? Just as long as the tiller is locked leeward, the jib is backwinded and the main is in the opposite direction of the jib...
I haven't been out yet (I just finished a two day ASA101) so I want to make sure I have this figured out.
Thanks!
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.”
Garret01 is offline
post #24 of 28 Old 07-05-2013
How to Heave To - Heave-to a Sailboat
Tom S.
O-Day 22
SchwarckT is offline
post #25 of 28 Old 07-05-2013
Garret01's Avatar
I thank you sir.
Garret01 is offline
post #26 of 28 Old 07-05-2013
Having a boat with a longer keel makes heaving to much easier. My O-Day 22 heaves to easily and is very stable, while my other two centerboard boats (15' Challenger and O'Day Mariner) don't really settle down well when I try to heave to.
Tom S.
O-Day 22
post #27 of 28 Old 07-05-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Originally Posted by travlineasy View Post
Wait till you get old and make the same statement. It's amazing how the aging process effects this function, especially when you realize that you'll soon be peeing on your shoes.
Cheers,
Gary
Or worse yet, as most of the time when the weather is warm enough I wear no shoes...
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #28 of 28 Old 07-06-2013
You might get better responses if you indicate what type of boat you are trying to do it with.
If I understand correctly, the ability to heave to and maintain that position indefinitely varies from boat to boat. For ours, we just tack from a close haul, leave the jib sheet, let out the main, and tie off the rudder to the opposite side. That's worked for every boat I've been on (Note: not many), but from reading I've heard that a number of boats require more work or just don't do it well.
I don't know how I'd reef if I couldn't get the boat to heave to
Shinook is offline
Heave to, WTH? T37Chef Seamanship & Navigation 30 10-08-2010 08:10 AM
heave to difficulty legarots Seamanship & Navigation 3 09-03-2010 11:29 AM
Heave to with a cat ketch freedom33 Introduce Yourself 1 03-08-2010 05:17 PM
Heave-To J-22 with no jib Starbuck1962 Seamanship & Navigation 14 09-26-2007 12:14 AM
Heave to? KAYAKDAN Learning to Sail 6 03-14-2006 08:44 PM
