My Horror Story - Page 12 - SailNet Community
 16Likes
post #111 of 191 Old 05-21-2013
Re: My Horror Story
Originally Posted by BubbleheadMd View Post
The condition of the ICW channels, and it's charts makes me seriously question using it for anything other than bypassing Cape Hatteras.
Nah, it's not that bad... Most folks who get into trouble on the Ditch simply aren't paying close enough attention... And often, in the case of a grounding, demonstrating a reckless impatience to get off immediately... Sometimes simply taking your medicine, and waiting for a rising tide, is most prudent course of action. Always amazes me how many people will call SeaTow on a quickly falling tide, when it's obvious that by the time help arrives, the boat will be so hard aground that the risk of damage, or injury in an effort to get off is very real...
Looks like these folks may have been done in by the piss-poor design of that Moody's underbody, that rudder looks to be even with, or within a couple of inches of being the same draft as the keel... Being West Coast sailors from SF Bay, perhaps they lacked an appreciation for the risk of such a configuration in the shoal waters of the East coast and Bahamas...
JonEisberg is offline
post #112 of 191 Old 05-21-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Re: My Horror Story
I have a swing keel that when up draws less than 3'. If I stay inside the markers I think I can motor without running aground.
If I do its sand and mud. I have patience for tide changes and if need be a gold membership to Towboat US.
Harborless is offline
post #113 of 191 Old 05-21-2013
CaptainForce's Avatar
Re: My Horror Story
Originally Posted by Sal Paradise View Post
Harborless did write
"So there I am direct under the bridge at 3000 RPM NOT MOVING. sitting still."
Yes, and this is why I was assuming that either his prop is fully fouled or it is not spinning; therefore, the questions,- Is the transmission disengaging? Is the shaft spinning? Is the prop fouled? Is the prop still there?
Nobody has a lack of momentum if a good prop is spinning with the engine at 3000rpm in a 26' boat with a new bottom paint when the current maximum is ca 2.0kts. I had hope that Harborless would tell us more of these answers to best allow some of us to give him some help.
By the way, the Moody that developed the hole and sunk after grounding near Ponce Inlet had completed a recent repair at the location of that hull failure.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #114 of 191 Old 05-21-2013
Re: My Horror Story
There is a thing called sod's law, or Murphy's law. Namely if something can go wrong it will. With experience, good preparation and prudent seamanship it may happen less and is usually easily overcome and minor. However if there is a shortfall the sea will find you out sometimes in benign conditions but more likely not.
I think there is a difference between dinghy sailing and a bigger boat. Also between being a crew and the one responsible, indeed the only one available. A range of skills have to be learned.
Okay you have done a fair amount of work. Sadly that is inevitable on an older cheap boat. It can seem never-ending particularly when you have to learn new skills and are short on money. That's boats for you, particularly old cheap boats. They are expensive and time consuming.
If the motor had been reliable and it seems you knew it was not or did not know it was, you would have run into less trouble but some as I recall.
Other people's boats can be expensive to fix, especially when a thousand is a lot. Most marinas require insurance. Can you not get third party insurance which is cheaper and doesn't cover your boat, just others. A sudden unexpected gust when docking or refueling shorthanded can do it.
Some anxiety is common, and most people experience some more stressful moments earlier on in their sailing careers. So I wouldn't panic about that rather continue to focus on building competence not just confidence.
By the way you may well find it takes more than 2 days to cover 80 miles. It isn't a straight line and steering for more than 8 hours is a pain. Trying to meet a deadline is a common source of problems.
Good luck.
chris_gee is offline
post #115 of 191 Old 05-21-2013
Older Junior Member
lsusailing's Avatar
Smile Re: My Horror Story
Harborless
Kudos for posting your story. First of all this is why we have a forum (I do not post a lot but I read every single post, great wealth of knowledge).
You did a good job articulating what you did wrong, and what you did right. At the end of the day, you won.
We all have done silly stuff, trust me, that is part of learning. There is a thread somewhere of silly stuff we have all done and it is worthwhile reading.
Harborless was honest in his posting and is asking for help. He received great advice which he can take or not take but it has helped him with his plan.
I am anxious to see what the diesel doctor says. It has to be an issue with transmission slippage or the prop. Even a bunch of scum should not slow it up that much but of course it could.
You learnt a lot on this trip so good show.
Keep us up to date, this is very interesting as we all have been in positions like this. Rest, hydrate, think, relax and tackle it. Just another day in paradise.
This is why we come back for more, it aint perfect and things will go bump in the night.
lsusailing is offline
The Following User Says Thank You to lsusailing For This Useful Post:
bljones (05-21-2013)
post #116 of 191 Old 05-21-2013
krisscross's Avatar
Re: My Horror Story
I have a swing keel and sail on very shallow and unpredictably shifty Pamlico Sound. I always keep the keel down at least 6 inches so that when I do run aground I can easily get off just by lifting the keel. I don't have any other depth gauge. Lowered keel is a good early warning system. Never needed anybody to get me off a sand bar in that little boat.
Plato
krisscross is online now
post #117 of 191 Old 05-21-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Re: My Horror Story
Well I have tried to describe the best I can what is happening. I mean, I did install the transmission myself but it is such a simple piece of machinary I do not understand how I could have installed it incorrect to allow slippage, but it is a possibility as it was my first ever transmission replacement.
Second, I did fill the oil a bit high, but its still not above the over fill mark on the dip stick.
Third, I wont lie. I did not clean the boats bottom, well not since Febuary. I am totally sure that barnacles ARE on the prop and that IS affecting propulsion. I did not realize the level of loss that barnacles can have on the prop but it sounds like a hell of a lot. lesson learned.
I am not sure what the problem is. White smoke starts, then grey to black. Diesel is seen in the water behind the boat. It runs away both in nuetral and forward, never reverse (thought I dont go in reverse long or often)
I do not put a heavy load on the engine (except when running from the railroad bridge- it ran away in an INSTANT with no warning. Tons of white smoke.
I will be on the boat during the work and will post everything along with some pictures. The prop is less than a year and a half old. Good 150$ prop just needs a cleaning along with the boats bottom.
I also leave my keel down a bit, thought I think I will leave it up while motoring the ICW.
post #118 of 191 Old 05-21-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Re: My Horror Story
Good luck.
After the engine is fixed the only thing left that can break is the keel. Im serious. Every single piece of equipment would have been replaced including the centerboard. I mean everything, not blowing smoke, EVERYTHING.
So with the diesel fixed I will be able to maintain an accurate maintenance law to keep Murphy at a distance, atleast for a season or two.
post #119 of 191 Old 05-21-2013
Re: My Horror Story
Originally Posted by Frogwatch View Post
BTW, check out the several youtube vids on ysm8 engines. I gotta admit, the YSM is a weird looking beast
Our 25 year old brought us from northern California to Florida. It's since been replaced for a physically smaller 10 horse but was still running fine when it was sold.
knothead is offline
post #120 of 191 Old 05-21-2013
Re: My Horror Story
I think you got the transmission right. The running away in neutral and not being able to shut her down with the choke almost clinches the too much oil thing as being right.
She starts and runs right but as the oil gets frothy she goes crazy and the smoke color changes to black indicating extreme rich mixture.
I've always been casual about too much oil and this has taught me a lot.
Frogwatch is offline
Keel, rudder, prop horror stories? deniseO30 General Discussion (sailing related) 3 08-17-2008 10:28 PM
Horror Trip tdw Cruising & Liveaboard Forum 3 05-08-2007 03:25 AM
Sailboat explosion survivor recalls horror - Naples Daily News NewsReader News Feeds 0 02-18-2007 03:15 PM
Horror on the high seas - when cruises go wrong (Stuff) NewsReader News Feeds 0 01-23-2007 12:15 PM
