Forestay Tack Position - SailNet Community
post #1 of 3 Old 05-20-2013 Thread Starter
The Catalina 22 has a three position forestay plate at the tack point. Can anyone elaborate on the performance changes that one might expect from displacing the forestay forward or aft from the middle point?
Thanks.
CS
cas8100 is offline
post #2 of 3 Old 05-21-2013
krisscross's Avatar
Re: Forestay Tack Position
It is all about mast rake. Read more here:
http://www.getwetsailing.com/mastrakeandrigsetup/
I'm not a racer so I usually keep mine in the middle.
Plato
krisscross is online now
post #3 of 3 Old 05-22-2013
Barquito
Barquito's Avatar
I don't think the hole you use will impact performance much. You can adjust mast rake (which does impact performance a lot) by adjusting the forestay toggle. I think most people put the forestay in the most forward hole, then use the other two for the jib shackle, a downhaul, a penent to raise a storm jib off the deck, or maybe for an asymetrical spinaker.
Valiant 32
Barquito is online now
The Following User Says Thank You to Barquito For This Useful Post:
cas8100 (06-02-2013)
The Right Tack capta General Discussion (sailing related) 4 01-19-2013 12:33 AM
Port tack faster than starboard tack, same point of sail? zAr Learning to Sail 28 09-06-2011 05:57 PM
How's my tack? RayMetz100 Learning to Sail 14 12-14-2006 12:29 PM
tack course agoodman Seamanship & Navigation 0 05-17-2005 05:15 AM
Pig to tack Dogsbody General Discussion (sailing related) 2 06-23-2003 08:12 AM
