Weight/size limits for autohelm 4000 - SailNet Community
post #1 of 10 Old 05-21-2013 Thread Starter
Sailnteacher77's Avatar
Hey everyone..
Considering an autohelm 4000 for a 43ft 23K lb sloop rig.
Any thoughts??
Jamie
Sailnteacher77 is offline
post #2 of 10 Old 05-21-2013
Re: Weight/size limits for autohelm 4000
You are over the weight specs, but so was I on my cutter. For motoring and light air it should work if you keep the weather helm down. In bigger seas and wind you will kill it and or your batteries.
ctl411 is offline
post #3 of 10 Old 05-21-2013 Thread Starter
I really only need it to serve as a back up crew member so I can take 20 minute naps.. cook some dinner.. hit the head.. make a quick repair or sail adjustment...
post #4 of 10 Old 05-21-2013
It will work fine for that just keep watch of the sail balance.
ctl411 is offline
post #5 of 10 Old 05-21-2013
Moderator
Jeff_H's Avatar
The answer lies in the specifics of your boat. If you have a boat with a lot of weather helm, dramatically changes helm loads with heel angle, or a helm which needs a lot of turns lock to lock, then its probably not up to the task. If you have a boat which has a light helm and is forgiving, then it might work. I have the Raymarine updated version on a 10,500 lb 38 footer and it works fine except that it is nearly impossible to callibrate the electronic compass so it actually reflects the proper course.
Jeff_H is offline
post #6 of 10 Old 05-21-2013
Aren't we up to a '6000' series with RM? If it's truly a used 4000 be careful of the (black) wheel drive ring assembly - lots of plastic bits prone to breaking as opposed to the newer (grey) version.
Faster is online now
post #7 of 10 Old 05-21-2013
JimsCAL's Avatar
And the 4000 is no longer supported by Raymarine.
JimsCAL is online now
post #8 of 10 Old 05-21-2013 Thread Starter
Good Points.... I had the newer raymarine.. i was not impressed at all. I miss my old Autohelm 300 belt drive. that thing was tough! .. I think I may hold out for a linear drive below decks.
post #9 of 10 Old 05-22-2013
poopdeckpappy's Avatar
I have a 4000 on a 37 ft'er @ 24,000lbs, Otto is pretty good helmsman that allows me to run around the deck, play with the sails, go below for a minute or two but that's all I allow him to do. Don't want him thinking he runs the boat.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #10 of 10 Old 05-22-2013
TomMaine's Avatar
Hey everyone..
Any thoughts??
Jamie
I have more than 10 seasons use on a 4000ST. Our boat is 38'6" and 15,000 disp. I've been surprised by how well it has steered the boat, most of the time in those 10 years.
It's done 95% of the steering in several Gulf of Maine overnights, much of that time under sail. It has no problem with wind forward the beam. I can adjust course, sail trim on our yawl off the wind, to have it do all the steering.
It get's tricky downwind with a good breeze and following seas, but so far, I've found a way for it to do the hard work on overnights, even downwind.
I'm nice to it(the WP, it's plastic) and make sail/coourse changes when it's working hard. I don't want to hold the wheel all night.
As coastal sailors, I'll happily get the newest version WP when this gives up(I'm on the second belt), knowing it'll do what we need without the expense and complication of an under deck AP.
I think you're use will depend on how well you can maintain an easy helm on your boat.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
Autohelm 4000 Gulfislander Gear & Maintenance 1 03-02-2009 06:58 PM
Autohelm 4000 k7pqs Gear & Maintenance 8 12-06-2008 10:31 AM
Autohelm 4000 Gulfislander Gear & Maintenance 8 01-19-2008 11:48 AM
Autohelm 4000 Booher Gear & Maintenance 4 10-15-2003 05:09 PM
Autohelm 4000 R33 Gear & Maintenance 1 10-17-2001 10:24 AM
