Rigging Math - SailNet Community
 1Likes
post #1 of 28 Old 05-22-2013 Thread Starter
davidpm's Avatar
Rigging Math
What resources would you recommend if someone wanted to run the numbers themselves for some rigging puzzles?
For example:
You replace your standing rigging with synthetic and figure you could shorten the keel a couple inches and have the same stability. How would you calculate that?
You are comparing two boats and want to calculate the margin of safety that the two builders used based on observed rigging.
You are thinking of replacing your chain-plates with titanium, how much smaller can you make them considering that titanium is several times stronger than steel.
You use a load cell to measure the force required to banana a boat with the for-stay and back stay. How do you calculate is that is the right amount of stiffness or if the boat has lost structural integrity?
In every case the answer is ask a navel architect.
But if such a person is not available or you want to check their work how would you make the calculations yourself?
davidpm is offline
post #2 of 28 Old 05-22-2013
blt2ski's Avatar
Re: Rigging Math
For #1, you might be able to lower the keel 1/4 of an inch, depending upon the size of the boat. For a C&C 115, making the mast out of carbon and going with somthing other than SS wire, save IIRC from a magazine article. 50 or so lbs up in the air, which translated to 200 less rail meat lbs! for a mid 20 ft boat, the same change in riggin saved as little as 50 lbs.
Reality is, there is some math that is involved, it is a matter of knowing the formula's, plugging in numbers, and seeing what happens!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #3 of 28 Old 05-22-2013 Thread Starter
davidpm's Avatar
Re: Rigging Math
Marty
Thanks for the comments on #1. That is the problem without the math it is not possible to know if any of these good ideas are really good ideas or not.
So I'm looking for resources to find the formula's.
davidpm is offline
post #4 of 28 Old 05-22-2013
norahs arc's Avatar
Re: Rigging Math
If you get a dregree in engineering you will have - or know how to get and use all the formulas needed. Much quicker to trust the engineering and design (but not necessarily the marketing) of reputable builders and designers.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #5 of 28 Old 05-22-2013
tommays's Avatar
Re: Rigging Math
I don't get the whole fiber rigging deal as the cheaper stuff is never a direct fit due to the sizes needed to stop creep
On the higher end you start at expensive PBO and work your way up to crazy expensive aero carbon rigging
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 28 Old 05-22-2013
denverd0n's Avatar
Re: Rigging Math
Can't help you with formulas, but...
The issue with chainplates is not the strength of the chainplate itself. If it were, we could get by with teeny-tiny chainplates, compared to what most boats have. The point is that you have to distribute the load to a large enough surface of the boat's structure. That is why chainplates are large--not because they have to be that big to handle the forces from the rigging.
denverd0n is offline
post #7 of 28 Old 05-22-2013
I don't discuss my member
zz4gta's Avatar
Re: Rigging Math
+1 Tommy, shrouds should be sized to be 10-20% of breaking load or less to mitigate creep. I'd error on the 10% side. That being said, better materials at better prices are coming out every day. And the reason Dux is so expensive is b/c they're the only company that is making a pre-stretch heat set dyneema SK75. That will change this summer.
Edit: Dux made by Hampidjan
zz4gta is offline
post #8 of 28 Old 05-22-2013
Re: Rigging Math
Anyone seriously contemplating such modifications probably ought to use consultancy services like Bob Perry's.. but as an exercise I'd suppose any structural engineer would have the necessary tools.
Faster is online now
post #9 of 28 Old 05-22-2013
grumpy old man
Re: Rigging Math
"Teeny tiny chanplates"? Go right ahead but don;t call me please.
The biggest load on the chainplate is the bearing load where the pin loads the hole in the chainplate. That load determines the size of the chainplate in terms of thickness and cross sectional area. But below the hole the chainplate can be considerably smaller. You can see this on the Valiant 40 chainplates where I doubled the plate thickness at the hole. I think most builders just use a single thicknes because it's easy to do.
Be conservative with chainplates. Having your mast in your lap can spoil a nice day of sailing.
Bob's Blog ....
bobperry is offline
post #10 of 28 Old 05-22-2013
denverd0n's Avatar
Re: Rigging Math
Okay, you got me. "Teeny-tiny" was an exaggeration (and how many millions of times a day do I remind myself not to exaggerate? ).
But the above is what I was referring to. If there weren't the issues of spreading the load adequately to secure the chainplate to the hull, then they could be made much, much smaller than they typically are. But those issues do exist, so even if you use titanium, while you might be able to use thinner material, the other dimensions would have to remain essentially the same in order to spread the loads out and adequately secure it to the hull, or through the deck to a bulkhead.
Jeff_h or other Math whiz... Cruisingdad Sailboat Design and Construction 16 09-10-2010 05:27 PM
Check my math davidpm Seamanship & Navigation 13 06-17-2010 07:03 PM
math of sailing jst04004 General Discussion (sailing related) 35 03-12-2010 02:36 PM
