New Windex...but Main Halyard Sheave Frozen??? - SailNet Community
post #1 of 5 Old 05-24-2013 Thread Starter
NewportNewbie's Avatar
Ok...I FINALLY had a guy go up the mast and replace my bent and worn Windex. He taped up my spreaders and at the same time lubed everything up. He said lightheartedly, "oh by the way your main halyard sheave is frozen...I lubed the heck out of it so maybe that will help.". I sail about twice a week so I figured he meant the spinnaker halyard since I have never used a spinnaker with this boat and the previous owners have not either. He again stated, "no its your main halyard.". I told him I sail all the time and raise and lower the main pretty easily. He said, yeah well it would be even easier if th esheave wasnt frozen....Maybe I'm wrong but wouldnt a frozen sheave make it VERY difficult to raise and lower the sail??
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 5 Old 05-24-2013
blutoyz's Avatar
Re: New Windex...but Main Halyard Sheave Frozen???
If it is all you've known you are used to it. Your sail may not be as heavy as you thought.
blutoyz is offline
post #3 of 5 Old 05-24-2013
I don't discuss my member
zz4gta's Avatar
Not really. A little hard but if it's always been that way, you're probably used to it. Don't believe him? Go up there and take a look.
If it were me, I'd plan on replacing the sheaves next time the mast is down.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #4 of 5 Old 05-24-2013
first sailed january 2008
northoceanbeach's Avatar
I have a frozen sheeve and can still raise and lower.
northoceanbeach is offline
post #5 of 5 Old 05-24-2013
Tartan 27' owner
CalebD's Avatar
Check for wear on the halyard where it runs over the sheave. Chances are your halyard is chafing a little every time you raise/lower your main sail.
Everybody has one:
CalebD is offline
C&C 32 main halyard sheave jharvey1215 C & C 2 02-17-2012 07:21 AM
Main Halyard on P-30 TBG P30 3 08-02-2011 04:58 PM
Main Halyard Fix bushrat Gear & Maintenance 4 08-05-2008 09:46 PM
Main Halyard theArchitect General Discussion (sailing related) 12 06-11-2007 10:17 PM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
