Air Tools and Compressed Air - SailNet Community
 1Likes
post #1 of 18 Old 05-24-2013 Thread Starter
美国华人, 帆船 教授及输送
I like air tools. I have that installed on my Jeep TJ as well as an on-board welder. It is very handy and trouble free I have never seen anyone has that on the sailboat. Why is that?
Go to a junkyard and pick up a AC compressor, make a bracket, get a new belt and install 6 to 10 gal tank (varies size). Done. $150 top.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #2 of 18 Old 05-24-2013
Omatako's Avatar
Re: Air Tools and Compressed Air
Air tools are noisy, expensive and take a lot of maintenance. And dragging an airline into tight spaces is challenging to say the least.
Give me a quiet, portable, small, inexpensive battery powered hand tool any day.
Just my preference, we all have them.
Minnewaska likes this.
Arthur C. Clarke
Omatako is offline
post #3 of 18 Old 05-24-2013
Air tools make my ears hurt.
Jeanneau 54DS
Minnewaska is offline
post #4 of 18 Old 05-24-2013
I don't discuss my member
Fstbttms's Avatar
Pneumatic tools do not last in a marine environment.
Fstbttms is offline
post #5 of 18 Old 05-24-2013
captflood's Avatar
GREETINGS EARTHLINGS; Hay What Pardon I Can Not Hear you the Compresser is running to keep up the air on my sander do you know sign language (Snigger giggle HA HA) Ear defenders are an opption . AS ALWAYS GO SAFE !
captflood is offline
post #6 of 18 Old 05-24-2013
JimMcGee's Avatar
I picked up a portable compressor for small jobs on board. $49 on sale at Xmas I think around $89 regular price. But it's a tool I take to the boat rather than one I keep on board.
I've used it on the boat and around the house for odd jobs. It's a lot easier than dragging out my big compressor and it works fine with my brad and finish nailers (haven't tried it with a framing gun). It should be fine with an air ratchet but you'd need ear protection using one inside a boat.
I never thought about keeping it aboard, but since it only draws two amps you could power it off an inverter (220W continuous, probably double that on startup surge current).
A lot easier than rigging and AC compressor and a storage tank running off your diesel. Not to mention if the diesel is down for repairs you'd have no air compressor.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #7 of 18 Old 05-24-2013
Don't get many flat tires on my sailboat.... but it would be good for loosening the engine mounts.
Seaduction is offline
post #8 of 18 Old 05-24-2013
tommays's Avatar
While they there strong points there about as energy inefficient as it is Possable to make a tool
My air drill will use 3 hp of compressed air no problem and I do much better with my onboard 18 volt battery tool recharger
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 18 Old 05-24-2013
Omatako's Avatar
I would say that that compressor will struggle to drive an air ratchet for any length of time.
I made the mistake of buying one about twice that size and it won't run a high pressure spray gun for more than about a minute or so and I reckon air tools use more air than a spray gun.
Arthur C. Clarke
Omatako is offline
post #10 of 18 Old 05-24-2013
JimMcGee's Avatar
Agreed, with two gallons in the tank it would be enough to hopefully break a stubborn nut. The compressor can only deliver about 0.5 CFM at 90 psi. I think an air ratchet on a continuous run uses around 4-5 CFM at 90 psi.
You could use it with an airbrush for touch-up work but not with an HVLP sprayer. It's great with brad/pin/finish nailers for cabinet upgrades.
Like I said it's a handy little odd jobber that saves pulling out the big compressor.
BTW, like your signature line. Arthur C. Clarke is a favorite of mine.
JimMcGee is offline
compressed natural gass Allen-deckard General Discussion (sailing related) 20 07-05-2012 10:42 AM
Using CNG - compressed Natural Gas Mark1948 Catalina 3 05-02-2011 04:16 PM
Compressed Air Cartridge for Life Jacket F4d3d Gear & Maintenance 15 10-26-2010 08:16 PM
Compressed Natural Gas (CNG) On Chesapeake Bay?? Sabreman Gear & Maintenance 4 05-22-2007 09:14 AM
New Tools rleslie Gear & Maintenance 2 10-23-2003 01:30 PM
