Radio direction finder app? - SailNet Community
 3Likes
post #1 of 16 Old 05-26-2013 Thread Starter
I looked at one boat when we were boat shopping, had a rdf oldschool from the '70s on a custom built shelf. Are these ever used anymore as back up?
And is there an iPad app? The ippad has a radio receiver doesn't it? Or is there a frequency issue?
Just googled nothing came up.
Just wondering, thank for any ideas.
b40Ibis is offline
post #2 of 16 Old 05-26-2013
Senior Pirate
TropicCat's Avatar
Re: Radio direction finder app?
Ipads aren't radios other than wifi or 3G or 4G- AM radio is an additional hardware item. wifi or 3G or 4G aren't available at sea without a satellite receiver. Unless you plan on going old school I doubt you'll be riding an AM radio beacon into port anytime soon. You'll use GPS and chart plotters like the rest of us.
Tropic Cat
TropicCat is offline
post #3 of 16 Old 05-26-2013
美国华人, 帆船 教授及输送
If it is for back up, bring another GPS. If for nostalgic reason, go for it and build one.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #4 of 16 Old 05-26-2013
scratchee's Avatar
RDF also requires a directional antenna, which the Ipad doesn't have.
scratchee is offline
post #5 of 16 Old 05-26-2013
Wish I never found SN!
SimonV's Avatar
And while your at it make a set of SEMAPHORE FLAGS for backup to the VHF.
Seaduction likes this.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #6 of 16 Old 05-27-2013
Omatako's Avatar
RDF was dependant on a signal being transmitted non-stop from a location that was not only known but was marked on your chart.
A directional antenna on the receiver on your boat was then used to sweep the area where you more or less know that the source of the signal will have come from.
When you're pointing the directional antenna directly at the RDF transmitter, it would be at its loudest and then you could lay off a bearing on your chart and your position would be somewhere along that line.
But as far as I can recall, there is no way that you could tell how far away the source was by the signal itself and things like the depth under your keel would work quite well to get an approximate fix.
So that's how it worked. Note I said worked because AFAIK there are no such signals being transmitted today so your antique RDF has zero practical use because there is nothing to receive.
Arthur C. Clarke
Omatako is offline
post #7 of 16 Old 05-27-2013
Mermaid Hunter
SVAuspicious's Avatar
Broadcast AM works fine. I used to use ZBVI on Tortola heading South.
You can still do it with the ferrite wound antenna in portable radios. The null is sharper than the peak.
SVAuspicious is offline
post #8 of 16 Old 05-27-2013
Senior Pirate
TropicCat's Avatar
Ahhh, you must be nearly as old as I am. I agree you could make something that would kind of work. The question is what for? Those AM transmitting antennas aren't in harbors.
Tropic Cat
post #9 of 16 Old 05-27-2013
weinie's Avatar
or you can buy vintage units on ebay for about $30 bucks!
weinie is offline
post #10 of 16 Old 05-27-2013
I'm probably wrong, but wasn't the null point indicating the direction of the AM broadcast station?
Seaduction is offline
A Little Direction surf_n_turf Boat Review and Purchase Forum 11 12-27-2015 12:41 PM
Newby needs direction Wheatear General Discussion (sailing related) 0 09-06-2011 10:40 AM
Help point me in the right direction tonyism7 Gear & Maintenance 19 07-29-2011 08:21 AM
Wind Direction pixurman Learning to Sail 5 05-22-2002 04:44 PM
RADIO DIRECTION FINDER SHIMSHON General Discussion (sailing related) 2 03-29-2002 11:38 AM
