Go Back   SailNet Community > Contributing Publishers > Good Old Boat
Like Tree1Likes
  #11
Old 12-25-2012
wolfenzee's Avatar
Location: S/V Waltzing Matilda, Port Ludlow, WA (NW Puget Sound)
wolfenzee is on a distinguished road
Send a message via ICQ to wolfenzee
Re: Hard dodger
Some I have seen is a piece of cloth (some with a clear plastic panel) that stretches from the dodger to the Bimini or boom gallows, not very big....just fills in the gap
  #12
Old 12-25-2012
wolfenzee's Avatar
Re: Hard dodger
a dodger can stick up like a sore thumb and make the boat look bad or it can enhance the lines of the cabin.....what makes the difference can be subtle, so making it out of card board and/or door skin first to see how it would look...see hao everything would fit is highly recommended. Look around at other boats what looks goo, what looks bad (this works for any changes to your boat...learn by other peoples mistakes, use other peoples good ideas).
I found a boat with similar lines (my cabin top is low with a lot of shear). low dodger, you have to make sure getting in and out of the cabin is not hindered, also make sure it doesn't get in the way of sheets, when you reef, does it hinder you vision, etc....
  #13
Old 03-21-2013
Saving Cash
macwester26 is on a distinguished road
Re: Hard dodger
I very much like this idea but i am not sure if it would suit my small boat .
the way to find out I guess would be to take a picture of the boat save it on the computor then draw over the image with a paint programme and see.
But what a great idea anyway.
Robert
  #14
Old 03-21-2013
Saving Cash
Re: Hard dodger
This is possibly my only option.
Something to think about.
Robert
  #15
Old 03-21-2013
wolfenzee's Avatar
Re: Hard dodger
Robert
The purpose of a dodger is to keep you dry(ish), this has to be accomplished without adding extra windage, getting in the way of the operation of the boat but has to look good doing it. The "soft" dodgers I have seen on Macwester 26s appear to "work", you could use the same shape (even the metal bows) for a hard dodger.
  #16
Old 03-21-2013
Saving Cash
Re: Hard dodger
What a nice image mine was the same colour.
Yes as you say the soft ones could be better. I could make them myself with a small clear view plastic window
I would have liked to have had the canvas top over the main hatchway door but our design is a bit different : our top hatch will be a lift up one on Gas shocks.
With a solar panel fitted in a recess on the top of it..
The reason it will give some cockpit protection. that will not need to be renewed or replaced.
This is a knockon effect from lifting the rear cockpit flooring to form channels for water to run off the deck into scuppers.
But could have been the way the last owner fitted the sliding hatch.It would not slide much...
You may post attachments
You may edit your posts
hard dodger vs. soft ktuthill General Discussion (sailing related) 15 10-01-2009 12:31 PM
Hard dodger and bimini S/V Perfect Partner General Discussion (sailing related) 2 05-14-2006 08:07 AM
hard dodger ventanamama General Discussion (sailing related) 0 08-28-2004 07:43 AM
Hard dodger elizabethrosema Gear & Maintenance 3 11-06-2003 07:23 AM
hard dodger vs soft heidi-peter Gear & Maintenance 4 02-05-2003 08:02 AM
SEO by vBSEO 3.6.1
