In this article, we hope to help you maximize your cleaning results while minimizing the amount of time spent with rag or brush in hand. Knowing which products work best for each application and understanding some basics about fiberglass care is the key to protecting the good looks and long life of your gelcoat, and ultimately the value of your boat. Dirt and Salt Dirt, grime, and salt all act as tiny abrasive particles on your decks and cabinhouse and should be considered your boat’s worst enemy. If left untouched, the simple act of walking about on deck will move around and grind these particles into the gelcoat. This activity will dull the finish of your once-shiny boat, and it can begin to shorten the life of your gelcoat. Salt left on deck can also act as a natural magnifying glass increasing the sun’s damaging rays, which will accelerate oxidation and hasten the break down of this surface layer.
Frequently hosing down of your boat with fresh water is the best course of action as it will remove much of the dirt, grime, and salt from the surfaces. Wiping the smooth areas with a rag, and employing a soft bristle brush to coax imbedded particles from your non-skid helps as well. But you should scrub gently though, as even repeated scrubbing motions can shorten the life span of gelcoat. We recommend that you combine your regular wash down with a specially formulated soap made particularly for fiberglass boats like Star brite’s Sea Safe Boat Wash. These boat soaps don’t remove wax like a high detergent soap, and most are biodegradable. When boat soap alone provides less than satisfactory results, you may need to resort to other means. First try applying a multi-purpose stain remover like FSR or Y-10 to the afflicted area. If you need even more muscle, cautiously employ an abrasive cleanser like Soft-Scrub or Bar Keeper’s Friend. But at all costs you should resist the temptation to over-use these abrasive type cleansers because they strip wax and abrade gelcoat surfaces. It’s easy to get into the habit of using this stuff too much due to the fast results you see, but later on the same area will get dirtier again more easily, and will become progressively tougher to clean due to its increased porosity. It’s really important that you avoid this self-defeating cycle or you’ll soon begin to wonder where that nice shine went and why the heck you can’t get it back. Organic Stains Identifying the source of a particular stain is usually the key to determining how to remove it. A stain that is organic in nature, like one caused by fallen leaves or annoying bird droppings, can be easily removed by applying a diluted bleach solution. Mix one part bleach with one part water and then pour or spray the mixture onto the affected area. We like to use a small spray bottle for easy application, but you should watch your footing as this solution ends up being extremely slippery. After several minutes, rinse the area thoroughly, let it dry, and then apply a new coat of wax. If you’re able to catch these stains early, your boat soap may suffice, saving you the bleach and re-waxing process. Waterline Stains In certain bodies of water, boats can develop a terrible stain at their waterline. One place where we’ve found this to be particularly true is along the Intracoastal Waterway. All vessels transiting these waters will develop a stubborn brown stain, which can often appear several feet high at the bow and extends aft along the waterline. This brown discoloration, commonly referred to as "ditch stain," can be one of the most perplexing stains to remove. We tried everything: bleach, abrasive cleansers, wax, rubbing compound, etc., all with no luck. Finally one day we discovered the secret—products containing acid. It’s not often that you find a cleaning approach that works instantly, but it was a happy day when we did.
Rust In addition to attacking waterline stain, acid-based cleaners are usually the solution for dissolving rust. To remove rust stains from the hull and deck, we again prefer the blue gel formulas of FSR and Y-10. We’ve found each of these safe to apply not only to gelcoat, but also to metal, painted surfaces, and even our synthetic non-skid, Treadmaster. Apply, let sit for awhile, and then rinse thoroughly with water. For stubborn rust, a second application may be needed, or a little soft-bristle scrubbing. For hard to reach deck areas like those around the bases of stanchions, use a toothbrush to coax the gel into the areas.
Wax and Polish One of the most important things you can do to protect your boat’s smooth gelcoat surface is to keep it waxed and polished at all times. And if you do this regularly, the surfaces will last longer and be easier to clean and maintain. By keeping small crevices in the gelcoat filled with wax or polish, dirt flows off your boat more easily. You need to be aware that many strong cleaners used to remove stains also strip wax and polish, so always re-polish after heavy cleaning. But don’t apply wax or polish to the non-skid areas of your boat though, as this will promote slipping. Just keep these areas clean with plenty of water and boat soap. If the smooth fiberglass surfaces are not kept waxed and polished, gelcoat can develop a dull, chalky appearance that is due to oxidation caused by prolonged exposure to the elements. This is particularly noticeable on colored hulls. You’ll know that oxidation is in its initial stages when you first notice your boat’s shine is gone and you can’t get it back. It’s in a more extreme stage when you run your hand along the hull and a chalky substance is left on your fingers. For detailed information on how to restore your boat’s finish, check out Don Casey’s article here on SailNet entitled Recovering the Shine.
In keeping our own boat protected, we prefer the liquid type of wax or polish as the application is easier than that of a heavy paste wax. We employ a paste wax when we need to remove dried varnish or paint from smooth gelcoat surfaces. Before scraping away the dried paint or varnish with a flat bladed window scraper, we first rub a little wax into the area to assist the blade in sliding smoothly over the surface and prevent digging into and nicking the gelcoat. Boat Names and Graphics Boat names that have been painted on your fiberglass hull can be removed by first applying oven cleaner, letting it sit for 15 minutes, and then wiping it away. To help remove evidence of discoloration between the hull and where the name was, use 3M Heavy Duty Rubbing Compound and lots of elbow grease. Vinyl adhesive names or graphics are sometimes impossible to just peel off, especially after they have been baked in the sun for years. To speed up the removal process, try heating the vinyl with a heat gun and use a flat scraper blade to coax it off the surface. Goo Gone or simple turpentine will help dissolve the adhesive still on the hull after the vinyl has been taken away. The key to keeping your decks and topsides looking nice is regular cleaning, but it helps to have a few tricks up your sleeve. Here’s hoping we’ve eliminated some of the trial and error for you regarding which products work and which don’t. As for the elbow grease, well, you’ll have to supply your own. Good luck.
SailNet Store Section: Cleaners, Polishes, & Coatings
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | Search this Thread |
