Harbor 20 - electric motor steering tips? - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 3 Old 06-22-2013 Thread Starter
Just took delivery of my first boat, a used Harbor 20 with a stern swing electric motor. In reverse with no way the stern goes hard to port, and in forward, bow swings hard to port. Rudder has no impact. Just want to go straight back or forward. It has been suggested I toe the motor in but not sure how it is attached to the swing arm, I am not having any luck twisting the prop end and don't want to break something. Thanks for any ideas.
ewilder is offline
post #2 of 3 Old 06-22-2013
ASA and PSIA Instructor
Re: Harbor 20 - electric motor steering tips?
With the prop behind the rudder, offset to starboard and fixed in position, you frankly have very little to work with. You can only steer that boat when you have enough speed that the waterflow past the rudder over takes your prop walk.
You need to reset any expectations about low speed boat maneuvering, and focus on getting on or off a dock manually...
sailingfool is online now
post #3 of 3 Old 06-22-2013 Thread Starter
Thank you. I suspected that was the case and appreciate the confirmation.
ewilder is offline
is anyone using an electric motor to get out of the marina ABH3 Boyer General Discussion (sailing related) 25 03-27-2013 09:31 AM
Replace Atomic 4 with Electric Motor? Wannafish Gear & Maintenance 29 05-13-2011 09:46 AM
electric motor mszczepa General Discussion (sailing related) 18 07-06-2010 06:24 PM
Does anyone use a Electric Trolling Motor poopdeckpappy Gear & Maintenance 23 10-19-2007 09:08 PM
electric motor for dingy saurav16 Gear & Maintenance 4 07-11-2007 02:46 PM
HTML code is Off
