Halyard Change - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 1Likes
  • 1 Post By jsaronson
post #1 of 7 Old 07-21-2013 Thread Starter
C&C 29 II
Halyard Change
Hello everyone. My first post, so be gentle.
Changing wire to rope halyards on my C&C 29II. The rope portion has torn apart at the clutch and they have been on there about ten years. Yale recommends the ULS (Ultra low stretch) and it is reasonably priced. Dacron sails, so I don't need spectra anyway. My question is the wire halyard pulleys at the top of the mast. Will they be ok with the 3/8 double braid running through them? or must I get up there and change them to a dedicated rope pulley? Who has done this before? Thanks for the input.
wcfrerichs is offline
post #2 of 7 Old 07-21-2013
Asleep at the wheel
jimgo's Avatar
Re: Halyard Change
I've done it on a Catalina, not a C&C, so take my comments with a grain of salt. But when I did it, the wire had really torn up the sheave. The walls were rough, and there was a deep groove in there. I was glad I had decided to swap out the sheave.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 7 Old 07-21-2013
Tartan 27' owner
CalebD's Avatar
Re: Halyard Change
Hi Warren,
Welcome to Sailnut!
I have not been up at the top of your mast in a while so I'm not sure what condition your masthead sheaves are in.
I think we have to replace the masthead sheaves on Odalisque too, as we've been using all line but have had to replace some halyards sooner than the 10 years you got due to fraying at the top of the mast.
We did convert our boom out haul from wire rope/line to all line a few years ago. I can tell you that there was one sheave that was badly worn by the wire rope which had to be replaced. The wire rope would jam in that chewed up sheave.
A cheap Delrin sheave from McMaster car was used to replace the worn aluminum sheave for this application.
If your masthead sheaves look anything like the one below you should probably go ahead and replace the sheaves before buying more expensive line.
Again, welcome.
Everybody has one:
CalebD is offline
post #4 of 7 Old 07-22-2013
Tartan 27' owner
CalebD's Avatar
Re: Halyard Change
Isn't there anyone out there with a C&C 29 II who has changed their masthead sheaves???
Any C&C model???
Everybody has one:
CalebD is offline
post #5 of 7 Old 07-23-2013
jsaronson's Avatar
Re: Halyard Change
C&C 35/3. Sheaves were not torn up and re-used them with 7/16 VPC. It all depends on condition. If the wire is in good condition you are probably OK.
Join cncphotoalbum.com for C&C specific questions. That's where you'll get the answer to every conceivable C&C question.
CalebD likes this.
jsaronson is offline
post #6 of 7 Old 07-25-2013
Re: Halyard Change
welcome to this community i am sure you would enjoy the stay here, make it large and memorable one for us.. dasvadaniya
MarkBarrett is offline
post #7 of 7 Old 07-27-2013
Re: Halyard Change
I ran new rope today on my little San Juan 23. I have external halyards so my job was easy. I use a staple gun to join the old and new rope. This is wrapped with tape to hold the staples in place. This will allow the rope to run without any knots to worry with. I had a wire main and it was driving me crazy at night as it was making noise on the mast everytime the boat would rock. I replaced the wiring inside the mast and wrapped the wiring with foam pipe insulation with excellent results. I am using 3/8 double braid everywhere on the boat and now I can sleep well on the weekend.
Griffinroydonald is offline
Tags
halyard. pulley , wire to rope halyards
C&C30 MK1 What halyard to use? ltgoshen General Discussion (sailing related) 18 06-10-2013 04:33 PM
halyard shackle letting go, spinnaker halyard interference ctlow Gear & Maintenance 13 05-23-2011 10:55 AM
how to change halyard eggman2001 Gear & Maintenance 17 03-10-2009 09:23 AM
halyard egregerson Ericson 9 11-09-2006 02:26 PM
jib halyard jbarros Gear & Maintenance 1 06-05-2003 03:36 PM
HTML code is Off
