anodes on a lead keel fixed with stainless 316 bolts - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 1 Old 09-19-2013 Thread Starter
I have recently started work on my 22ft plywood bildge keeler, one of the keels was fully detached from hull and hanging on by the last three (of 5) bolts. so I am rebuilding the timber section of the keel and fastening with stainless 316 bolts, also i will encase the keel in fibreglass.. two things Im not too sure of, do I need anodes? If so advice on installation? and any idea's on how to fix the stainless bolts to the lead keel? wire brush the inside of bolt holes - melt lead and pour into the groove? as I take it oxidisation/corrosion can occur if there is a crevice between bolts and lead?
the result is offline
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 60 08-29-2015 01:03 AM
Replacing lead Keel bolts cousineddy Gear & Maintenance 30 10-20-2012 10:24 AM
316 Stainless Bolts casey1999 Gear & Maintenance 16 02-09-2012 11:53 PM
Replacing recess fixed ports w/stainless steel trim patrscoe Gear & Maintenance 4 10-12-2011 11:03 AM
new bolts on encapsulated lead keel Santa30 santana30 Gear & Maintenance 2 07-02-2007 06:50 PM
HTML code is Off
