Perkins 4-108M Switch details - SailNet Community
Blogs
Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
Old 04-22-2008
pbanderson is on a distinguished road
I am trying to replace my engine switch and Perkins is less than helpful and don't make a replacement. The wires are a mess and I don't know where they terminate. Does anyone have a wiring/terminal diagram for the 4-108m ignition switch.
Old 09-01-2008
dancamp is on a distinguished road
no, I don't know, but I have the same question. My ignition switch on the same motor on my sailboat has quit working and i need to install a new ignition switch, that comes with no schematic or instructions.
Old 09-01-2008
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Ahh! I see I'm not the only one frustrated by Perkins wiring!
I've found that the engine owner's and workshop manuals are not quite exact in this area, since it's obvious that my instrument panel is generally different than those shown in the diagrams.
Which switch do you have? Is it the four position (Off, Run, Preheat, Start) switch, or a two position (Off, Run) with separate starter and kill buttons?
Old 12-13-2008
switch detail -- Off, Run, Preheat, Start
I got the same problem. I just bought a Perkins Ignition Switch 2846129 and it is a Off - Run - Preheat - Start switch. I think the switch itself has five termanals with one or two of them double. I'm not certain as it's on the boat and I'm at home.
I also cannot find a schematic or anyplace else and would like to know where the many different wires go to this switch. I've got a Perkins 4-108 in a boat. Before the old ignition key froze and I had to buy another, it also had an alarm (maybe a low oil pressure alarm) hooked to it. I put a temporary ig. switch in till I could get the original online. In the meantime, I lost all original info that I had written down before removing all the wires.
any help would be great
HTML code is Off
Tachometer/ignition switch for Perkins 4-108 M jmunson2 Gear & Maintenance 0 04-21-2008 10:57 AM
Perkins Head Gasket & Hello to All islandzephyr Gear & Maintenance 3 05-21-2007 12:38 PM
Battery Switch johar Gear & Maintenance 4 04-08-2003 05:28 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
Mainsail Details Brian Hancock Gear and Maintenance Articles 0 06-19-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
