Ahoy from the SF Bay - SailNet Community
Blogs
Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
Old 01-27-2009
jgsteven is on a distinguished road
Talking Ahoy from the SF Bay
Hello!
I recently moved to the SF Bay area, and bought a 1969 Discovery 32, an older and very simply appointed 'plastic classic'. The hull was in great shape and the boat had been re-powered with a Yanmar diesel about 10 years ago, but had almost nothing in the way of interior furnishings or electronics. Over the winter months of 2008 and 2009 I have been working on updating it a bit (GPS, automatic bilge pump) and getting it ready for an active summer on the bay and the pacific coast.
Old 01-27-2009
camaraderie's Avatar
moderate?
Nice looking boat! Welcome aboard.
Old 01-27-2009
sailortjk1's Avatar
Welcome, can't wait to hear more about your refit/projects.
Courtney is My Hero
Old 01-27-2009
Upgrade project: electrical system
Well, my most recent refit was adding AC shore power (Jan 09). I installed a very simple system, only to power an onboard battery charger and one electrical outlet (GFCI equipped, of course).
It was pretty straightforward, although there are a couple of things I learned that might be useful to others:
1. Blue Sea systems makes a really great set of pre-fab panels that have all the breakers installed. I got one with a 30A double pole and 3 15A single pole breakers as well as a voltmeter and reverse polarity warning light for less than $200.
2. Marinco GFCI's wire sockets aren't large enough for real wire (who wires their boat with 16 gauge wire?!?!). I got a tip from another owner with the same problem who told me you could force the holding screws out of the outlet, and use ring terminals (which worked) but I was pretty disappointed in the quality of the Marinco GFCI. I suspect I could have gotten an identical quality one from Home Depot for cheaper (that didn't say 'Marine' on it).
Finally, I also had to make a little wood panel to mount it on and I used 'West Marine Semi Gloss Wood Finish' instead of varnish for the first time. It offers the benefit of no thinning or sanding between coats, and you can overcoat it with varnish. The panel turned out well (picture below) so I think I am going to try this on my brightwork once the weather gets a little warmer.
Regards,
Joe
HTML code is Off
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 116 09-04-2011 09:05 PM
Avoid the Bay Bridge if all possible... aa3jy Chesapeake Bay 0 08-28-2008 04:27 PM
Sail boater missing in bay of Green Bay - WBAY NewsReader News Feeds 0 06-11-2007 04:15 PM
Cruising the Bay Islands Liza Copeland Cruising Articles 0 08-20-2002 09:00 PM
Landfall—Glacier Bay, Alaska Liza Copeland Cruising Articles 0 08-17-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
