Roller Furling Headsails - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 3 Old 05-21-2009 Thread Starter
I just purchased a Southern Cross 31 that has a year old headsail inventory of hanked sails. I want to add a roller furler and would like to know if the luffs of my current sails can be converted to accomodate the furling system.
Algentry is offline
post #2 of 3 Old 05-21-2009
Tartan 27' owner
CalebD's Avatar
The short answer: yes, you can convert them from hank on to luff tape for a furler.
The long answer: sails that were made with hank on luffs should really have some foam added along the luff so the sail furls better. This will add to the cost of adding the luff tape by a sail maker.
If it were my boat I would probably try going a season with the hank on inventory as you say they are only 1 year old. If you still had a hankering for a roller furler then I would think about getting a new sail with the furler (say a 150%) and maybe have one of the better, smaller jibs fitted with luff tape for higher winds. I think there is a slight difference in the way the sails are cut to fit on a furler so the hank on sails may not work as optimally as they could.
Everybody has one:
CalebD is online now
post #3 of 3 Old 05-21-2009 Thread Starter
Thanks for your response. A 150 is more than I need and is diffcult to get around the staysail stay when tacking. I wonder if converting the yankee to luff tape would cost sail performance. The boat doesn't exactly burn up the waves as is.
Algentry is offline
Storm sails and roller furling headsails? wallybygolly Gear & Maintenance 10 12-05-2008 05:25 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 09:00 PM
HTML code is Off
