omc saildrive - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 3 Old 06-11-2009 Thread Starter
omc saildrive
I have a 15 hp OMC sail drive motor. When I'm under sail I can hear a whirring noise from the motor compartment. I am assuming that this is the prop turning. If the prop turns while under sail, does this cause any sort of drag on the boat? If so, should the prop stop turning if the motor is in gear? I leave it in gear, but I still hear the noise. Can you tell me what the problem is?
wananooky is offline
post #2 of 3 Old 06-11-2009
timangiel's Avatar
did you turn the blower off? just kidding, if you put the engine in reverse the prop should not turn. I'm not sure what you are hearing, does it sound any different when in gear as opposed to in neutral?, and is it a fixed blade or folding prop?
timangiel is offline
post #3 of 3 Old 06-25-2009
I Don't know what you're hearing, but I always leave the motor in gear when under sail. The motor makes a knocking noise in neutral and jumps around a little. I'm wondering if your bearings are in good shape. May want to check them when you haul out. Good luck
Dallis is offline
OMC Saildrive Parts ARE Available kennethgelao Gear & Maintenance 12 05-25-2014 12:25 AM
Used OMC Saildrive Parts Available in VT iadanza Gear & Maintenance 2 10-27-2008 10:31 AM
OMC Saildrive Mount trsdos Gear & Maintenance 0 10-19-2008 10:03 AM
OMC Saildrive billybee Gear & Maintenance 1 09-03-2006 05:19 PM
OMC saildrive Jim Malcolm Gear & Maintenance 0 06-20-2002 02:12 PM
HTML code is Off
