6 vs 8 hp four stroke outboard - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 4 Old 06-26-2009 Thread Starter
I have a 1964 columbia 26 which weights around 5300 lbs. I'm kind of on the fence between buying a 6hp and 8hp Tohatsu four stroke. Since I plan on sailing on SF bay I don't want to be under powered.
Any advice?
slimpicknns is offline
post #2 of 4 Old 06-27-2009
saildork's Avatar
Welcome aboard, Slim. I sail a Catalina 22 in protected inland waters. I have a 7.5hp 4-stroke Honda which is more motor than I need for the 2500 lbs it pushes. A friend of mine uses the same motor on his C25 which weighs over 4000 lbs. The 7.5 hp motor is better suited to his boat than it is to mine.
Just based on that, I would say that for the SF Bay, you would want the 8hp motor for your boat. Maybe some of the SF Bay sailors on the Net could give you a better idea of what would be optimum for your situation.
Sailing isn't a matter of life and death. It's much more important than that!
saildork is offline
post #3 of 4 Old 06-27-2009
mstern's Avatar
A 5300 lb 26 footer in those currents? 8hp, no doubt.
mstern is offline
post #4 of 4 Old 06-27-2009
you can always go slower even if you have a bigger engine. But if you get in a bad current you want the power to be there
sck5 is offline
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 13 12-02-2014 10:55 AM
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 06:15 PM
The Great Stroke Debate Tom Wood Cruising Articles 0 03-31-2003 07:00 PM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
HTML code is Off
