Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
  #11
Old 08-16-2010
waynecollett is on a distinguished road
Originally Posted by Jeff_H View Post
That does not look like a plug in that it has wide planking and punched web frames instead of bulkheads. Plugs rare can be converted into actual boats since plugs lack the proper structural design to be a boat. My best guess is that this is a wooden boat that someone glassed over. Between the punched web frames and the concrete ballast, that's a pretty scary object passing as a boat!
the fibre glass is nearly two inches thick. it weighs 5 tons
  #12
Old 08-16-2010
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
If the fiberglass truly, really accurately is 2" thick, then whoever built it, knew nothing about fiberglass design for a boat of that size and type.
2" thick fiberglass is so extremely thick and overweight for a 38 footer particularly when you say that the whole boat weights only 5 tons, especially with that hull form, and especially when combined with your earlier assertion that the boat has the concrete ballast, that if true I need to double up on my original comment; that is a terrifying object attempting to masquerade as a sailboat.
Either that or perhaps you are mistaken. When you think about a 5 ton, 38 footer, the hull (except at the keel) is usually in a range around 1/2" to maybe 3/4" of fiberglass thickness. As the thickness of the fiberglass in the hull gets thicker than that, it means that there is less weight available for proper ballasting and for a proper internal structure, let alone interior furnishings, tankage and the gear that is needed on a boat. And since concrete is a very low density ballast, you would need a whole lot more ballast or place it a whole lot deeper than say a boat that had lead ballast, and the keel cavity on the boat in question is pretty short in length and draft that means that the concrete is not especially deep in the water either.
So if your numbers and materials are right (5 tons, 38 feet, concrete and 2" thick hull) then I would seriously recommend parting that mess out and looking for something safe to sail. But if as it appears, you are dealing with an older wooden race boat that someone has glassed over. That would be good news compared to either the assumption that someone has tried to turn a plug into a sailboat, or that the boat has a 2" glass hull.
Respectfully,
  #13
Old 08-16-2010
JohnRPollard's Avatar
Moderator
Originally Posted by waynecollett View Post
give me your email , i can send photo easier than trying to load them on here.
Best to load them here, where more eyes will see them and increase your chances of a correct i.d.
  #14
Old 08-16-2010
Respectfully,
just got hold of the seller, whos said hes had a survey done, sending it to me asap.
its 2inhes thick where the deck is joined to the hull, bit of a state as im cutting it about to insert reinforcements for the stanchions pulpits etc, took a skin fitting out and the fibreglass is about 12 to 15 mm thick. thinking about ripping all the wood out and putting in new bearers all round , or leave the wood in and fibre glass it all in, the only rot ive found is where the deck leaked ontop of the timbers inside. seeing as its a shell ive got all the options open to me . ive got loads and loads of epoxy glues , fibreglass, resins etc , i got all the time in the world as well. im loving it. except for when it rains that is.
by the way this boat came with a 50ft mast and a smaller mizzen mast. so it was set up as a ketch. all the rigging is good condition. now all i need is a pot of money and a sense of humour. might be ready for next year.
  #15
Old 08-16-2010
Moderator
... now all i need is a pot of money and a sense of humour. might be ready for next year.
I don't mean to rain on your parade. Just trying to caution you about the costs and time involved in such an undertaking. You could easily expend far more money on this project, than it would take to purchase a respected design that is ready to sail today.
And that ready-to-sail boat would likely have more residual resale value than this one, which has uncertain pedigree and will amount to a "one-off" even if fitted out more-or-less correctly.
You are about to get involved in a MAJOR undertaking. You have to like working on boats more than sailing them to get involved in a project like this. And whatever you do, don't undertake this project thinking you will get your money back when it's done. That possibility is remote at best.
Nevertheless, best of luck!
  #16
Old 08-17-2010
Jeff_H's Avatar
Administrator
Appears to be a Hughes 38
The photos appear to be of a deck from Hughes 38 (AKA Hughes Northstar 38) or a similar S&S design. These were built in Canada in the 1970's. The interior clearly appears to be a wooden hull with race boat framing from the late 1960's or early 1970's. If I remember correctly this appears to be a very similar design to P.M. Edward Heath's Morning Cloud 1. The perferated frames was sometimes used as a weight savings move in that era when wooden boats were still seen as being potentially lighter, and stiffer stiffer and also stronger than similar weight glass boats.
I do not believe that the Hughes 38 or any of the S&S 38's were available as a yawl. Given the lines of the boat, and if she was every actually rigged with two spars, then more than likely the intent was to rig the boat as a yawl and not a ketch.
When you talk about restoring an old boat of this era, it is not something that should be done lightly. Adding or subtracting weight will impact how the boat will actually float, and how much stability it will have. When it comes to structure and hull thicknesses, you want just enough to make the boat strong enough that you can sail the boat reliably. Randomly adding structure can only negatively impact the boat's sailing characteristics, carrying capacity, and safety.
My point here is this, if you were an experienced boatwright, and if you had access to a good yacht designer, restoring a boat like this can be done and end up with an okay (or slightly better) boat. It would mean rigorous reverse engineering of what you have and then careful design to produce what you want when you are done.
But you show not even the slightest sign of being experienced, or rigorous in your approach. Your basic descriptions of what you have show a general lack of knowledge of what you have bought and the process required to get to a finished boat. Its not for me to say this since you probably know this already, but sometimes it is helpful to see this in black and white, you basically have three choices here: 1) Stop for a moment and do some careful homework. Learn about the boat you bought in real detail and develop an engineered plan for your work before you do any more harm to the old girl, 2) Roll the dice and hope for the best. Having designed a few boats in my day and read your post, I respectfully suggest that given your approach and knowledge level, the dice are loaded against you at this point, or 3) Realize that rebuilding a derilict is not for everyone and that buying this old hull was probably a mistake that can be reversed by getting rid of these parts of a boat one way or another, and while that may prove expensive, it would not be as expensive as blundering ahead.
And if you are considering continuing with plan 1 or 2 you need to bear in mind that a hull, old engine and some rigging represents perhaps 20% of the overall costs to rebuild a boat. The material and labor to properly rebuild and upgrade an old boat of this size to a yacht level of finish can easy run $80- 100,000, of which the labor is about half.
And if all is done with a high level of skill and attention, and the boat was in perfect shape, if it has a really clever layout and perfect finsihes, and a like new engine, and great sails, and good deck hardware and reasonable electronics, given the limitations of the dated hull design, it might be viewed be a moderately nice one-off with a value somewhere in the $20-30K range. Those are huge "if's".
As John points out, you can buy similar boats ready to go for far less, get out there sailing sooner, and have something which would be easier to sell when you are done with her.
Respectfully,
You may post attachments
You may edit your posts
Interesting Sailboats PCP Boat Review and Purchase Forum 4399 56 Minutes Ago 05:06 PM
390 foot - 300,000,000.00 yacht poopdeckpappy General Discussion (sailing related) 26 08-16-2010 05:33 PM
Inquest finds yacht name mix-up causes sailor's death Hartley18 General Discussion (sailing related) 46 08-03-2010 04:46 PM
SEO by vBSEO 3.6.1
