01-23-2011
Variable Geometry Wing Sails
Hi,
I am new to SailNet and have been prompted to join by reading many posts about the virtues and drawbacks of wing sails. Along with my brother, I have been involved in wing sail research and development for more than 20 years. Unfortunately, due to time and budget limitations this has been far from a full time pursuit. However, I have had a considerable amount of experience with wing sails and also had a lot of success. We have reviewed a considerable amount of literature and I believe we have understood the limitations of some of the research. It is only through the combination of research from many authors that the theoretical and practical performance of wing sails can be understood. If this is then backed up by practical experience, it provides confidence that the theory is correct.
So there are some myths I would like to rebuff:
Myth 1: Thin cambered foils produce less drag than thick foils.
This is simply not true for the practical range of operation of a sail on a yacht. Wing sails will produce comparable lift and in almost all circumstance considerably lower drag (by as much as an order of magnitude). There is a plethora of research to back up this statement. Much of the research is misquoted by people who either have not understood it or look no further than the piece of information that backs up their position. In the correct configuration (of thickness, camber, angle of incidence, etc) thick foils outperform thin foils in the practical range of wind speeds experienced in a yacht.
Myth 2: You cannot fit a wing rig to an existing boat without major modifications.
I own a 25’ light displacement monohull. I bought the boat second hand and other than moving the chain plates to support a rig with swept back spreaders I needed to make no modifications to the boat. I have also had similar rigs on an 18’ skiff, a 20’ trailer yacht, a 28’ displacement yacht, a hobie 18 and a windsurfer.
My current rig is fractional and has one set of spreaders (though this is not a limitation). It uses conventional sheeting and vang arrangements. It can be reefed while sailing. It can support headsails and spinnakers. My current sail plan is a 23 m2 wing main, a 10 m2 conventional headsail and a 45 m2 asymmetrical spinnaker.
Myth 3: Wing sails are too heavy.
The rigs I have used on the above boats carry only a marginal weight penalty over a conventional rig. The extra weight is attributable to having two sets of battens. The mast is of comparable weight to a conventional mast – due mainly to being able to carry a much larger mast section (and thus reduce wall thickness). The sails are only marginally heaver (even though there are two skins) as the wind load on the sail is shared between both skins, as are leech and foot loads.
I agree with many of the posts that many wing sails in use today are heavy, complicated and have practical limitations. However, this does not need to be the case.
Below is a photo taken from under the boom (while the boat was on the hard stand). I hope it reproduces well enough for you to see both the leeward and windward skins on the sail. The photo shows the rig with very little camber and around 12% thickness (i.e. nearly 400mm between skins on a 3.3m foot).
The rig can be easily set up in many configurations. The diagrams below show some of these.
Thickness is controlled by mast rotation, camber by outhaul.
So, in summary, I would like to contribute to the discussion on wing sails. I know that they can be a practical and economic alternative to conventional rigs. I also believe we are at the very beginning of the next performance curve.
Cheers
