03-30-2011
Your meter is broken. Do you have separate "AC Voltage" and "AC Amps" meters? The measurement of "Amps" is dependant upon load, so if you can turn on some high usage items (water heater, hair drier, etc.) then you should see the ammeter show usage.
I'm not sure what you mean by switching between 110V and 12V - one is AC and the other is DC and one needs batteries and a charger and perhaps inverter to switch between the two.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
