Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
Old 05-19-2011
Huntertime is on a distinguished road
Advice on putting my sailboat on a mooring buoy
Hello Sailnet
Can I get some advice on how to put a sailboat on a mooring buoy and not have the mooring buoy scar or tear up the side on my sailboat.I have just bought a used 240 Hunter that is really good shape and I dont want to abuse the hull of the sailboat.
Thanks again for any and all post.
Old 05-19-2011
hellosailor's Avatar
Hunter, you don't tie the boat directly to the buoy. Typically you'll tie two ten-foot long lines to the ring on the top of the buoy, and bring each of those up to a bow cleat on your boat. The wind or current will keep your boat off the buoy most of the time. Yes, sometimes it will rub up but mooring buoys are usually required by law to be large WHITE buoys with blue marks, and the white vinyl(?) doesn't seem to mark hulls.
All of the hardware, from the bottom of the mooring to the rod in the ball and the connections to the lines, has to be inspected for chafe and wear regularly. If something pops and your boat breaks free--that's a much bigger worry.
Old 05-19-2011
sailortjk1's Avatar
As HelloSailor has stated, some are required by law to be white and blue.
In some areas this is not enforced. I know an area where it is not enforced and a great many of boaters use protection like this to protect the boat. In areas of no currect and known calms it can be a hull/paint saver.
Check with the local authorites having jurisdiction or check with other boaters in your area. If the law enforces the White and Blue Strip, than disregard my post. If it's allowed they are easy to make.
Courtney is My Hero
Old 05-19-2011
jjablonowski's Avatar
jjablonowski is on a distinguished road
Yeah. Safety first
In a slip you get to rub up against concrete and/or wood with maybe a little rubber or canvas coating.
On a mooring you get to rub up against ... water.
Which will do less harm?
That said, there are indeed dangers on a mooring. Nothing to be petrified about, but you should go in with your eyes open.
Fellow SailNetter 'Maine Sail' has put together a Very Impressive set of postings on his local Web site. This particular link shows some of the prep you must consider.
HTML code is Off
Mooring advice needed CascoBay Gear & Maintenance 40 04-29-2010 04:03 PM
Putting sailboat into Corporation zboss Boat Review and Purchase Forum 34 03-15-2010 02:38 PM
Bridle for Buoy Mooring maddata General Discussion (sailing related) 21 09-05-2008 06:29 PM
Protecting Re-Painted Topsides from Mooring Buoy wolfmt General Discussion (sailing related) 5 02-11-2008 11:14 AM
Mooring advice needed dscottl General Discussion (sailing related) 12 04-25-2002 02:59 PM
