Evans 16 owner - Page 2 - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #11 of 25 Old 07-25-2011
Hello gentlemen
I too have recently purchased an Evan's 16. Do either of you have a manual to explain the rigging? So far I have the mast up and in place, but Mark I like your idea of running a line from the mast to the end of the boom to keep th ebook up when the sail is not up.
If either of you could take photos of yoru boats from front to back, especially close ups of the lines, pulleys and cockpit rigging I would appreciate it. I have having a hell of a time simply figuring out what goes where.
Thank you for your help
Neil
Neilio11 is offline
post #12 of 25 Old 07-25-2011
My boat lies at Etobicoke Yacht Club. If your in the area you can come have a look.
amcnewman is offline
post #13 of 25 Old 07-25-2011 Thread Starter
There are Evans boat pictures posted on the Evans 16 user group website. I also had alot of questions and have now had most of them answered. Raiseing and lowering the mast should not be a problem. I have a pretty good simple system that I use. Mike
petey256 is offline
post #14 of 25 Old 08-02-2011
Well I got her up and sailing on the weekend. Got the main sail up only, but will work on the jib next. Had to hoist the mast 3 times as I kept forgetting things or to do things that I need to do when it is down, but it gets easier each time.
I appreciated your tip about running a line from the top of the mast to the end of the boom to keep it up when the sails are dropped. A big help to have that much extra deck space. Thank you
Any idea where I can buy the hand rails that mount on the bow of the boat? Have seen them in pictures and look nice. Thanks again gents
Neilio11 is offline
post #15 of 25 Old 06-09-2012
Re: Evans 16 owner
Just managed to get on this site. Not sure if anyone still monitoring but I am interested in anyone else owning an Evans 16. Just got mine in Picton On. She's now in Parry Sound. A 'fixer upper'. Biggest concern just now is a 'sticking' swing keel that I'd like to repair. Anyone out there with clues as to possible causes? I will probably not have time to work on her til the fall but would welcome any ideas. Thanks, Glen.
glen p. is offline
post #16 of 25 Old 06-09-2012
Re: Evans 16 owner
Welcome to the community Glen. Sorry I cant say I have had a similar issue with my Evans 16. There is a small Yahoo group of Evans 16 owners Out there. someone may have an idea. evans16 : Evans 16
post #17 of 25 Old 06-09-2012
Re: Evans 16 owner
Thanks for getting back to me, amcnewman.
If all else fails, I will attempt to shoehorn the keel out but in no rush. Have seen a post on another site with a similar concern but no responses to them. Given it was 2010, I suspect it's a dead link.
Will also watch the yahoo group site for evans 16 and will hope to learn.
glen
glen p. is offline
post #18 of 25 Old 06-11-2012
brehm62's Avatar
Re: Evans 16 owner
Originally Posted by amcnewman View Post
When you say boom vang I assume you mean main sheet.
I laughed when I read this. Here is a picture of the end of my boom. You can still make out the original manufacturer's label on the end. Yes, it is mislabeled as BOOM VANG when obviously the double block is for the main sheet. This confusion of terms is not that uncommon on small sailboats even in owner's manuals and labeling coming directly from the manufacturer.
brehm62 is offline
post #19 of 25 Old 06-11-2012
brehm62's Avatar
Re: answers my questions
Originally Posted by petey256 View Post
My sail is the same as yours so it will have to slide inside the mast. I wonder if wax or something would make it easier to hoist. Well forget wax cause here in Florida it would just melt, but maybe something else.
You might try a dry, silicone lubricant. It needs to be a dry spray so that it doesn't leave an oily film on the fabric. Sprays like this one are non-staining.
brehm62 is offline
post #20 of 25 Old 06-11-2012
brehm62's Avatar
Re: Evans 16 owner
I tied a thin line to the top of the mast and extended the other end to about 30" away from the end of the boom and attached a pulley to that end. I then attached a second line to the end of the boom then fed it through that pulley back towards the end of the boom through an existing pulley attached to the boom then tied to a cleat attached further along the boom.
That's an interesting configuration. You must have an extra cleat on the boom. Mine only has the cleat for the outhaul but I do have extra cleats on the mast so mine is cleated there just like the main halyard.
brehm62 is offline
E40 Owner svGeneve Endeavour 4 08-02-2012 05:09 PM
New Owner 473 migpilot Beneteau 20 11-03-2011 12:00 PM
New C&C 32 Owner Here markstoport C & C 3 05-12-2010 04:38 PM
Possible new owner delatush Pacific Seacraft 2 04-25-2010 05:22 PM
HTML code is Off
