Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
  #1
Old 02-19-2012
jed091751 is on a distinguished road
Scout troop has inherited a CAL 21
Our boy scout troop has inherited a CAL 21, and I've read that they are great boats. First we need to check out the keel closer to make sure its ok; hvae read some scary stuff about the keel rig! Are there folks out there who have worked on this boat and can offer advice? Thanks!
  #2
Old 02-19-2012
Tournant's Avatar
Tournant is on a distinguished road
Try calling and sweetalking local surveyors into "donating" an inspection
Are there any Sea Scout Ships nearby you can contact?
Good Luck!
  #3
Old 02-19-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Cal's in general have a pretty good reputation.
Here are the specs for the Cal 21': CAL 21 sailboat on sailboatdata.com
It seems to be a center board/swing keel model. Definitely a good idea to check out the condition of the pivot pin as well as the pennant (line) that lifts and lowers it.
Also important to check out the chain plates (where shrouds and stays connect to the deck) on older boats.
I hope you and the kids have a blast with it.
Everybody has one:
  #4
Old 02-20-2012
PaulinVictoria's Avatar
PaulinVictoria is on a distinguished road
Welcome, and what a fantastic opportunity for the kids.
To err is human. To arrr is pirate.
Orange Crush (for now)
1974 C&C27 MkII
  #5
Old 02-29-2012
tommieg is on a distinguished road
Your Cal 21
Hi,
I've owned a Cal 21 since 2002. I've done some work on it since that time and have enjoyed sailing on Lake Michigan and other midwest lakes. It is a great boat! Make sure all of the standing rigging is in good condition; turnbuckles, chain plates, wires, etc. I've replaced both the forestay and the backstay and upgraded all the turnbuckles. I replaced the stainless bolts that secure the chain plates to the interior bulkheads after I discovered two bolts had corroded to the point of dropping their heads. This could have been very bad had the bolts failed under sail. I also removed the swing keel and installed a bronze bushing in the steel plate tightening up the fit between the keel and the pivot bolt. My boat has only been sailed in fresh water and the metal was all in very good condition. You will also want to be sure to have and use the keel plug that fills the space through the hull that houses the keel when it is retracted. I have a really good solution to holding the plug in place and covering the opening in the cockpit floor. Let me know if you are interested I can share what I did at that location.
I've cruised side by side to wind with J 22's and a Melges 20 and was able to keep with these high performance boats on Lake Charlevoix in Northern MI. I would not rate the Cal 21 as a good boat to learn to sail with kids. It can be a handful in winds over 20 mph. We've been able to stay upright in gusts to 40 mph. under jib and main.
It is a good sturdy boat assuming that the hull is solid and all wood stiffeners are not rotted. I did need to completely replace the structural wood frame that joins and reinforces the joint between the stern and the deck.
I completely stripped the mahogany rudder and glassed it and coated it with performance epoxy. I stripped the bottom paint and repaired some minor hull damage caused by the trailer and then gave it a couple of coats of epoxy and finished it with VC17. I have a 6 horse Nissan 4 cycle outboard on it.
  #6
Old 03-01-2012
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
I'd also call the local Power Squadron and USCG Auxiliary, there are volunteers with both who probably will be glad to come by, check the boat, give a safety talk and a boost to your program all at the same time.
You may post attachments
You may edit your posts
Sea Scout Ship in need of a A-4 for P30 SkipperShip1BSA P30 9 05-26-2010 01:50 PM
Supreme Court Denies Berkeley Boy Scout Troop (NBC 11 Bay Area) NewsReader News Feeds 0 10-16-2006 12:18 PM
"Inherited" Charts Mclion71 Cruising & Liveaboard Forum 5 09-30-2004 04:43 PM
SEO by vBSEO 3.6.1
