A furler for A-sym and Staysails? - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 1Likes
  • 1 Post By tdw
post #1 of 7 Old 04-19-2012 Thread Starter
Is there a furler that would work for an Asymmetrical spinnaker and a wire luff staysail?
agrosalmon is offline
post #2 of 7 Old 04-19-2012 Thread Starter
Re: A furler for A-sym and Staysails?
Sorry maybe more info is needed.... I sail an Ericson 39 that is set up for a staysail (running backstays and all) and I would love to justify a furler for the staysail that could double duty as a spinnaker furler too.
Thanks.
post #3 of 7 Old 04-19-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Thanks.
I stand ready to be corrected but as far as I am aware that is not going to happen. Yes you can have your assy on a furler and yes you can have your staysail on a furler but not the same one I'm afraid.
jackdale likes this.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #4 of 7 Old 04-20-2012
overbored's Avatar
most of the new assy / code 0 furlers can be used to furl any sail that has its own luff torque rope or wire. the luff rope stays on the sail and the furler and top swivel are attached and hoisted with the sail. once hoisted the sail can be unfurled and again furled. when the sail is lowered the furler is removed from the sail and can be used on any other sail that you have set up for the furler. for spinnakers the newest thing is the top down furler. built like a code 0 furler but with a bottom swivel. this type can double for both types of sails, spinnakers or headsails.
http://www.westmarine.com/webapp/wcs...g-Sail-Furlers
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 7 Old 04-20-2012
Yes..
Facnor have a furler called the FX series, that can be used for code 0 and staysails (with wire/dyneema luff).
With the FX/ASYMFX kit you can also use it for the asymetrical spinnaker.
Look at this brochure for details
http://www.facnor.com/uk/products/as...s/asymfxuk.pdf
For some reason they does not advertice much for this product (would rather sell two furlers?
I use this on my boat
knuterikt is offline
post #6 of 7 Old 04-20-2012
tdw
tdw's Avatar
..... boy am I glad I kicked my post off with "I stand to be corrected"
― Terry Pratchett.
tdw is offline
post #7 of 7 Old 04-21-2012
I didn't even quote you
It's worse when a sailmaker tell his customer that it's impossible or to costly to adapt an existing asymmetric to a furling system.
The only modification needed to use this system i a small reinforcement patch with attachment for the central furling line in the middle of the luff, my local sailloft charge $100 for this job.
Tags
furler , spinnaker , staysail
Which Furler? sdinger General Discussion (sailing related) 7 03-09-2012 07:50 PM
New Furler rig tension jetdrvr393 Gear & Maintenance 15 05-19-2011 02:15 PM
A Furler? jetdrvr393 Gear & Maintenance 6 11-10-2009 08:56 PM
Split or Double Backstays? Mizzen Staysails.. MedSailor Gear & Maintenance 7 05-06-2008 07:21 PM
New Jib Furler sailr4 Gear & Maintenance 0 10-23-2002 12:46 PM
HTML code is Off
