Brand new Honda 5HP Outboard won't start - should I switch mfg? - Page 2 - SailNet Community
Advertise Here
Go Back   SailNet Community > Welcome to Sailnet > Introduce Yourself
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you. NEW!
Old 10-16-2012
skytop is on a distinguished road
Re: Brand new Honda 5HP Outboard won't start - should I switch mfg?
The problem is the ethanoll fuel the misdirected and controlling government forces us to use.
Either switch to pure gasoline which is available at many stations now OR... use the ethanol crap gas and add an enzyme addititve to keep the ethanol from gelling.
The tiny jets and passageways in these outboards very easily get clogged with the inferior ethanol gas we are forced to use to pay off government corruption and payoffs for subsidies. Burning our food is a crime and the world hates America for it while they starve.
  #12
Old 10-17-2012
FishDragon's Avatar
FishDragon is on a distinguished road
Smile Re: Brand new Honda 5HP Outboard won't start - should I switch mfg?
Interestingly enough, what I eventually found out was the REAL problem, was that leaving the choke on for more than a few seconds after it started was fouling the plug. I've been using the motor for several months now, and the routine I use is to pull out the choke, start it, then push the choke all the way back in immediately while turning up the throttle a little bit to keep it running. In short order the motor warms up enough that I turn the throttle back down to minimal idle, then when I'm ready, I head out.
Per earlier advice I got on here, when I'm done for the day, I unplug the fuel hose and let the engine run until the carb runs out of fuel, and I ALWAYS close the breather vent on the fuel tank when it's not in use.
Using these two methods, my motor has run flawlessly all summer - but then again, it IS a Honda!
  #13
Old 10-17-2012
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
The only outboards that I seem to be able to keep running year in and year out are old 2 strokes. They burn dirty gas, they burn water.
  #14
Old 10-17-2012
FishDragon's Avatar
water? that's an amazing accomplishment - maybe even planet-saving! lol
Tags
motor , outboard
You may post attachments
You may edit your posts
Honda outboard problems Variant_530 Gear & Maintenance 15 04-17-2012 09:27 AM
Honda 5HP outboard oil pressure razimm Gear & Maintenance 0 06-27-2011 11:11 AM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
Honda Outboard Motor xenetia Gear & Maintenance 0 04-19-2001 02:50 PM
Honda Outboard GGartin Gear & Maintenance 0 01-14-2001 05:14 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
