ReinellSailboatWindow - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 2 Old 06-04-2012 Thread Starter
Hi
We have been sailing since 2008 in a late 70's Reinell Sailboat
We have done one improvement each year including patching the bottom (it almost sank the first time we had it in the water), re-wiring, and re-placing the interior. it has two long wing shaped windows that are cracked and allow water to leak inside. I want to replace or at least repair these windows.
Does anyone have a clue about how to go about this?
I would prefer to replace-can you recommend a re-sale shop for boat parts
thanks
KennyLeeJennyLee is offline
post #2 of 2 Old 06-04-2012
Re: ReinellSailboatWindow
You can get the acrylic material from most any plastics shop.. if you can get the old window off in one piece they can use it as a template and cut new for you for a reasonable cost as a rule. Clean the old sealant off as completely as you can.
Buy 'plastic cutting' drill bits, and drill the panels to match the existing fasteners, quite 'oversize' for the size of the fasteners themselves to allow for expansion.. those ports are quite large, IIRC. I think it's better not to countersink, and use panhead screws or bolts to reattach the new port.
Carefully mask the area around the port inside and out, and use a sealant like Dow Corning 795 as an adhesive/seal. Gently, evenly tighten the window, avoid depressions in the panel at the screw holes. The DC 795 will end up holding most of the load, the screws are there mostly to hold it while it cures.
Wipe the excess sealant carefully away, remove the masking and 'voila' there you are.
Faster is online now
HTML code is Off
