New to Lewmar Winch Maintenance - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 5 Old 06-30-2012 Thread Starter
Smile New to Lewmar Winch Maintenance
HI! I'm not so new to sailing, but new to doing my own maintenance on our 40St & 44ST Lewmar Winches. I've taken apart the 40ST. Can anyone tell me how to tell if the gear spindles and pawlings are worn out? The grease is heavy and dirty looking. I'm not sure they've ever been serviced. Thanks for the help.
SailinRM is offline
post #2 of 5 Old 06-30-2012
Courtney the Dancer
jrd22's Avatar
Re: New to Lewmar Winch Maintenance
I think there was a good thread here a few years ago about how to service and clean them, might even be a YouTube video (it would be surprising if there wasn't). They are pretty easy, if you've done your 40 you shouldn't have any trouble with the 44s. I got some Lewmar grease, I'm sure any light grease would work.
Here you go:
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 5 Old 07-05-2012
Senior Pirate
TropicCat's Avatar
Worn out? If the gears are clean and the pawls aren't chipped, you're fine. Put some new grease on them and you're good to go.
Tropic Cat
TropicCat is offline
post #4 of 5 Old 07-05-2012
Moderator
Jeff_H's Avatar
What the video does not say is that when a winch is not "perfectly clean", cleaning the winch can be a very messy process and the parts can sometimes stick together and then seemingly randomly pop loose. Because of that when I service a winch, I typically will cut a larger than winch diameter hole in the bottom of a large-ish cardboard box, put the box over the winch and tape it to the deck. I then work from within the box.
I also put a little diesel oil in the bottom of a gal. milk jug and use the oil and an old toothbrush that to clean the old grease off the metal parts. NOTE: I do not clean plastic parts with diesel oil. I don't know whether the diesel oil will damage the plastic, and assume not, but prefer not to take chances on that.
I typically do one winch at a time, but do the winches of the same type one after the other so that I remember the lessons of that winch type when I do the next. The only problem on my boat is that I still have two really ancient Lewmar geared, single-speed, self-tailers which I have not figured out how to disassemble. I rarely use these and the good news is that they work about as well as really ancient Lewmar geared, single-speed, self-tailers can, but one of these days I will ideally replace them, or at least figure out how to get the things apart and lube them.
I must say that I am never 100% sure what to use for oiling the pawls. For many years, I used a machine oil that was made for lubing machine tools parts. When that ran out, I started using the same motor oil that I use in my boat's transmission. I am not really sure that it matters, except that you don't want to use the thicker grease used for lubing the rest of the winch.
Lewmar is pretty good about selling rebuild kits for their winches that include pawls, springs and many of the smaller parts. The good news is that I can typically do all five of the modern winches on my boat in about an hour. That said, the whole process takes almost 2 hours since the set-up and clean up takes almost as long as the cleaning.
Jeff_H is offline
post #5 of 5 Old 07-05-2012
jsaronson's Avatar
The Lewmar maintenace kits usually imclude oil for the pawls. It is much lighter than motor oil. Harken sells a tube of similar oil. You can get it at West and elsewhere.
jsaronson is offline
Lewmar old-school winch maintenance geary126 Gear & Maintenance 17 09-21-2012 06:13 PM
Lewmar winch Foxsea Introduce Yourself 4 06-06-2011 01:19 AM
Lewmar maintenance lisasailor Gear & Maintenance 10 04-05-2011 12:39 PM
Winch Maintenance - Help with Older Lewmar 40s CLucas Gear & Maintenance 3 02-03-2008 08:50 AM
Older Lewmar Winches, Maintenance PrarieRose Gear & Maintenance 3 04-12-2007 04:53 PM
HTML code is Off
