Yanmar - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 4 Old 07-13-2012 Thread Starter
Yanmar
Hi All,
Question: I recently purchased a CAL 27 sailboat with a Yanmar inboard diesel.
New to diesels and never had an inboard on a sailboat. That said...
She runs nicely and shifts smooth...But the neutral isn't easy to find and the prop seems to spin a little, which jogs the boat to the port side while in neutral. It's slight but noticeable when waiting a the dock...Is the normal?
cmeyer179 is offline
post #2 of 4 Old 07-14-2012
Senior Cruiser
sea_hunter's Avatar
Yes.
sea_hunter is offline
post #3 of 4 Old 07-14-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Re: Yanmar
Check the transmission. Most Yanmar engines are coupled to transmissions that are required to be filled with oil. When the oil gets low they start to act up. Also go to the Catalina Yachts (Yachts and boats for sale - Catalina Yachts) web site and get the technical support number. Call them. They are very helpful.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #4 of 4 Old 07-14-2012
Send a message via Yahoo to dacap06
Re: Yanmar
No, I do not think that is normal. I have Yanmar 2GMF and it doesn't do that. The transmission oil advice is good advice (and you should check it so you know the level) but probably is not the problem. It sounds to me like the clutch is not fully disengaging. I suspect the transmission cable needs to be adjusted. You can tell easily sitting at the dock with the engine off. With the transmission in neutral you should be able to turn the shaft by hand without much effort.
A cable adjustment is easy. Take a look at section 9-7, Remote control cable adjustment, in your engine manual to see how the shifting mechanism works. If you don't have a Yanmar engine manual and your engine happens to be a 1GM, 1GMF, 2GM, 2GMF, 3GMD, or 3HF, you can download this one. Or, you can talk to a mechanic at your marina and have him do it.
Let us know how you get on with it! If you have questions, we'll help if we can.
Regards,
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
yanmar ysb 8 ecarson General Discussion (sailing related) 0 08-25-2010 03:08 PM
yanmar gm ray1 Diesel 0 05-04-2010 04:16 PM
Yanmar 2GM zfactor Boat Review and Purchase Forum 5 06-08-2009 11:00 AM
Looking for a Yanmar 2GM knotslo General Discussion (sailing related) 4 03-04-2009 08:12 PM
Yanmar warwicksail Gear & Maintenance 3 12-15-2007 12:30 PM
HTML code is Off
