Honda Guy Here... - Page 3 - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 1Likes
post #21 of 27 Old 12-06-2012 Thread Starter
Re: Honda Guy Here...
Originally Posted by bnaylor View Post
Robert: Re: "The jet is pretty easy to replace in most smaller outboards. I could post the procedure for the BF5 if needed." ... Yes, please, that would be helpful.
I need to get my "post count" up a bit before I'm allowed to post attachments, so hang on....
robert@hm (Honda Marine)
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@hm is offline
post #22 of 27 Old 12-06-2012 Thread Starter
Originally Posted by Stumble View Post
Have you guys given any thought to making a small (2.5hp or smaller) high thrust outboards?
[snip]
...would it be possible to bring a very small outboard to market? Say 1hp. Most racers want the lightest outboard we can find
[snip]
There is a pretty big market for a sub 20lb motor, regardless of price, or hp rating just to hit rules requirements.
How about a high thrust prop on a Honda BF2.3? It clocks in at 29.5 lbs. dry, and with 0.29 gallon of fuel, that would be about 31.3 lbs. Now that's with the OEM plastic prop.
While the standard answer to any new product idea is the company is always looking at new concepts, etc., it's obvious there has to be a good business case for any investment. A lot of factors come into play; in the USA market, the biggest and most profitable products tend to focus on giant marine engines > 200 hp. No doubt if sailing (kicker motors) was as popular as bass fishing, there would be a slew of lightweight outboards.
post #23 of 27 Old 12-06-2012 Thread Starter
Okay, here you go...BF5 carb jet service, and jet table...
FYI, I had to make these as .JPG files, since sailnet.com doesn't appear to allow .PDF files. If these images aren't clear enough, send me a PM with your email and I'll email you the .PDF files direct.
BF5 Carb + Jet_Page_1.jpg   BF5 Carb + Jet_Page_2.jpg   Carb Jetting Bulletin_Page_1.jpg   Carb Jetting Bulletin_Page_2.jpg   Carb Jetting Bulletin_Page_3.jpg
post #24 of 27 Old 12-06-2012
chucklesR's Avatar
A sub 20 lb engine
Heck, get three or four.
chucklesR is offline
post #25 of 27 Old 12-06-2012
Stumble, at those prices I'll have to start visiting third world countries looking for old two-strokes, shipping them to the Khyber Pass for rebuilds (hey, good machinists are hard to find) and then reimporting them to the US.
Of course, you realize that a thousand dollars doesn't buy much titanium, or even one hour on a really light high-compression racing engine. :-)
hellosailor is offline
post #26 of 27 Old 12-06-2012
Hello,
There is real profit to be had in very small lightweight engines. You can import used ones, just not new ones for sale, so yes there is profit in it. Find one of the old seagull 1hp 12lbs engines and you could start a bidding war on sailinganarchy over it. If they work even better, but just having them is the key. Or take a few to some small boat regattas, and you could easily get 800-1000 each, the lighter the more valuable.
The problem is anything 5hp or bigger is going to be the same weight as a new 4stroke, so it's not worth the bother. But the small smokey, won't crank, things people used to throw away are now worth a mint. Just call the local engine shop and ask them if they have any, any where there is a sailing scene there is a waiting list 20 boats long looking for them.
Robert,
The engine I bought was 18lbs. I have no idea how much fuel it carries because I have never put gass into it. The racing rules require me to have an engine onboard, and demonstrate it works when required, they do not require me to carry any fuel onboard (we have 1 cup of gas in the engine for rules requirements that it starts). This is a problem faced by thousands of racers in the US where new two strokes can't be sold.
The EPA rules are driving people to using weed eaters with props on them, 45lb trolling motors, and all sorts of other weird stuff. It isn't just the weight on the boat, it is the problem of taking it off the boat and storing below before every race that is the problem. Pulling motors off the back is a good way to drop them overboard....
Greg
Stumble is offline
post #27 of 27 Old 12-06-2012
chucklesR's Avatar
Greg,
Not to run away with the thread -
Just take a 45lb thrust trolling motor, rip the head off and put a weed whacker/leafblow/chain saw motor on it, done. It doesn't even need to have the crank shaft connected to the drive.
At no point did you say it actually had to work and move the boat.
I get a hour of run time with my leafblower's motor at full throttle.
Honda 2hp ?? tsingtao Gear & Maintenance 42 05-28-2013 05:32 PM
Honda 2hp 4-stroke flyingwelshman Gear & Maintenance 4 07-26-2012 11:56 AM
Honda 2hp smoking dnf777 Gear & Maintenance 5 09-03-2011 10:34 AM
Honda EU2000i Gen poopdeckpappy Gear & Maintenance 7 12-09-2010 08:24 AM
Honda 100 smillinjack General Discussion (sailing related) 0 11-10-2009 08:28 PM
HTML code is Off
