Solar guy - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 2Likes
  • 2 Post By jimgo
post #1 of 9 Old 02-16-2013 Thread Starter
Solar guy
Greeting & salutations!
I'm joining the group more as a resource than anything else. I was drawn to the forum by a solar panel question, and would like to stay in touch.
Cheers all!
MoeIsMe is offline
post #2 of 9 Old 05-06-2013
Re: Solar guy
Welcome as a resource! I have a question about charging with solar and alternator. My boat has three AGM batteries two for house and one for starting. They are connected to a 1-2-ALL-Off selector switch. I have installed a 50W solar panel and have wired it through a controller directly to the house bank only. Id like to also keep the starting batterys charge up with solar and think that by turning the selector to ALL, that will do it since all 3 batteries are connected to it. Im wondering if the batteries, solar panel, controller or any other component could be damaged if I charge the same batteries with solar while the diesel is running and the alternator is also throwing a charge into them? Can I simply leave the switch to ALL whenever charging with alternator and/or solar? Is there a simple, not-too-expensive way of monitoring all this charging?
seadoug is offline
post #3 of 9 Old 05-06-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: Solar guy
Cheers all!
Your bright comments and sunny disposition will shed some light on a highly-charged subject, eclipsing some of the wired-in rising stars with shocking results!
jameswilson29 is offline
post #4 of 9 Old 05-06-2013
Asleep at the wheel
jimgo's Avatar
Re: Solar guy
James, that was horrible. I've reported your post as abusive. Not to the OP, but to the rest of us!
bljones and jameswilson29 like this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 9 Old 05-07-2013 Thread Starter
Re: Solar guy
Shocking indeed! I'll try to stay grounded as I navigate the positive experience of this forum!
Graham Morfitt, BSc(physics), DiplBA
Owner, Modern Outpost
- Whether you think you can, or think you can't, you're probably correct
MoeIsMe is offline
post #6 of 9 Old 05-07-2013
bljones's Avatar
Re: Solar guy
It's okay- with enough charge the inmates here are easily LED to their cells.
Oh, frack me...i am reduced to nerdpuns.
It's 5 o'clock somewhere:
bljones is offline
post #7 of 9 Old 05-07-2013
Re: Solar guy
Reduced is right!!!
Faster is online now
post #8 of 9 Old 05-07-2013
norahs arc's Avatar
Re: Solar guy
Re charging with solar - running the engine and alternater at the same time won't harm anything. (FYI I have solar at home and on my boat )
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #9 of 9 Old 05-07-2013 Thread Starter
Re: Solar guy
The common terminal approach will be fine. Both the alternator & the solar are in the same voltage range, plus the solar charge controller will turn off the input from the panels if the voltage of the batteries indicates they are 'full'. Basically, you will likely only see solar charging when the alternator is not running, since the charge controller will see the charging voltage from the alternator and decide that it has nothing to offer.
I would recommend going with a good quality charge controller such as MorningStar or EcoEnergy. You will probably want to size the controller to accommodate any future expansion of the solar... 6A will support approx 100W of solar.
I hope that helps... let me know if any other specific questions arise during your hunt for equipment.
MoeIsMe is offline
Tags
solar panels
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Going Solar Squidd Electrical Systems 0 10-12-2012 10:54 AM
solar help smallboatlover General Discussion (sailing related) 7 08-16-2012 04:20 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
think they use solar ? sailusvi General Discussion (sailing related) 0 10-08-2007 08:12 PM
HTML code is Off
