PUMP Out issue with 33i - SailNet Community
post #1 of 6 Old 10-26-2015 Thread Starter
I have to hold my hand over the holding tank vent to pump out - what is my problem
f1yman is offline
post #2 of 6 Old 10-26-2015
Learning the HARD way...
eherlihy's Avatar
Re: PUMP Out issue with 33i
you're doing it wrong. :-/
eherlihy is offline
post #3 of 6 Old 10-26-2015 Thread Starter
OK can you tell me what I'm doing wrong because no one at the Marina had a clue
f1yman is offline
post #4 of 6 Old 10-26-2015
Old enough to know better
I will say if you cover the vent you run the risk of imploding the tank so don't do that. The line for the pump out should lead to the bottom of the tank and air should only be able to be drawn into the vent by the drawing out of the effluent. There must be a leaking connection somewhere that will not allow the vacuum to form. I would suspect the fitting between the hose leading to the holding tank, then the fitting between the pump out port and the pump-out hose. Is the suction on your hand strong? How old is the boat? Has anyone done any work on it? Has it always done this? Is there any odor in the boat near the holding tank or pump-out fittings. When they are pumping out have someone go below and see if they can hear any hissing. Perhaps someone reconnected the hose incorrectly when working on it?
miatapaul is online now
The Following User Says Thank You to miatapaul For This Useful Post:
f1yman (10-26-2015)
post #5 of 6 Old 10-26-2015 Thread Starter
Thanks
She is a 2010
I did replace the manual head this spring and will inspect all clamps again
The vacuum is strong at the vent
No odors
f1yman is offline
post #6 of 6 Old 10-26-2015
Are you sure you have the Y valve in the correct position, and the pumpout seacock closed?
MarkSF is offline
Westerbeke voltage/lift pump issue. MRF James Gas 1 10-11-2014 12:07 PM
Coolant circulation issue - is the water pump working? jaybeegee Diesel 11 02-14-2013 12:42 PM
Sump Pump Issue djangodog Gear & Maintenance 7 04-10-2012 05:30 PM
Yanmar 2GM injection pump issue? kcford Diesel 10 05-03-2011 10:03 PM
Bilge pump issue JSailer Gear & Maintenance 22 01-04-2009 11:08 PM
HTML code is Off
