Jeanneau Attalia - Page 18 - SailNet Community
 6Likes
post #171 of 277 Old 09-22-2013
JensK's Avatar
Re: Jeanneau Attalia
Dear Waymar
Going E when the wind i SE is about 45 degress to the wind, as an absolute wind angle. Your relative wind angle probably was around 30 degrees (if your boat speed was about of the wind speed - calculations by head). This is actually about what can be expected. My boat goes 25-30 relative degrees on one tack and 30-35 on the other (do not know why is is different).
In flat water you may point higher, in waves you will have to point lower to keep up speed (such as 45 degrees relative angle). Rather than just pointing high, I would balance this aginst the speed - always aiming for 5 knots or more upwind when the wind is 8-10 knots or more.
I got a new mainsail last year - wonderful to look at - but we are not doing better in the races ;-).
Best regards
Jens
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
post #172 of 277 Old 09-22-2013
JensK's Avatar
link to new mainsail (I hope)
Jens
https://plus.google.com/photos/10548...CIm21r3K_N6xCA
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
post #173 of 277 Old 09-22-2013
blt2ski's Avatar
I point at about the same degree's as Jens. Sometimes a bit higher. Then again, I have laminate sails. I personally see no reasions to go with dacron these days, as laminates are about as cheap as dacron, but seem to streth less etc. So one gets a bit more power etc in lighter and heavier winds.
Not sure doing the bow would be a good thing. Putting an extension on the rear, ie a true sugar scoop has been done to many of this era. One way to extend the WL of your boat cheaply anyhow. Look at the sunshine 36/38 boats to see how this was done.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #174 of 277 Old 09-23-2013 Thread Starter
Not quite Senior Member
Waymar83's Avatar
Send a message via Yahoo to Waymar83
Thanks guys,
The bow extension is not going to happen. I can just imagine what it would do to the balance, let alone trying to get a shape that would not disturb fluid flow. Although its an interesting thought as it would not affect the overall length of the boat, like a scoop on the stern would. That has also crossed my mind as a platform is always useful.
I've been looking at the polar diagram Jens sent over and it makes sense. I guess I get close to that as well. We had 2-3 meter waves and were also going against the current so I should not have expected better. But what a slog!
Jens looks like you got yourself a full batten package.. Looks nice!
Mark
Now based in Barbados.... and wait for it.....the boat is too!
Waymar - Jeanneau, Attalia
Waymar83 is offline
post #175 of 277 Old 09-23-2013
JensK's Avatar
Dear Mark
Yes, in those waves and with current and wind against you, I would certainly also have a slog. No wonder that the police called you ;-). Anyway, this was very nice of them.
Only way out is a slender, high pointing boat going through the waves - and you would be soaked for hours. Unfortunately, we cannot have both (at the price).
Yes, the full batten mainsail is certainly an advantage. Go for that the next time. Even though the mainsail is smaller than the genoa, I believe it plays a major role for speed and pointing, because of the channel effect.
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
post #176 of 277 Old 09-25-2013 Thread Starter
Waymar83's Avatar
This is what I picked up this week from Practical Sailor: The Effects of a Tidal Stream on Navigation
The effect of a tidal stream is a significant factor when navigating on any point of sailing, but can be crucial when sailing to windward. If you are in a small boat sailing to windward against a strong tide, it can often prevent you from making any headway at all and it may be best to enter a port or anchor until the tide or wind changes direction. If this is not possible, you should try to keep to shallow water, away from the strongest stream. The presence of a strong tide will also affect the strength and direction of the apparent wind. When the boat is beating against the tide, the apparent wind speed will be reduced because the boat is being carried downwind. The converse also applies. When the tide is running across the wind on the lee bow, advantage can be gained because it increases the speed of the apparent wind and alters its direction so that the boat is effectively freed and can point higher. When the tide is on the windward bow, the effect is the reverse, so try and tack when the tide changes to keep it on the lee bow..... Wondering if this would have the same effect just offshore.
Mark
Waymar83 is offline
post #177 of 277 Old 09-26-2013
blt2ski's Avatar
ANY current would be that way. Have had same effects with a canoe/kayak in a river.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #178 of 277 Old 09-29-2013 Thread Starter
Waymar83's Avatar
I need local knowledge....
On another note, do either of you know where the holding tank is? I am challenged by a new smell and am trying to locate the source.
Mark
Waymar83 is offline
post #179 of 277 Old 09-29-2013 Thread Starter
Waymar83's Avatar
Found the holding tank! (In the cockpit locker actually). Never needed to know before... Any idea how to discharge the head directly overboard bypassing the holding tank? Very useful for those trips to St-Lucia or St-Vincent. Also what is the purpose of the Y valve in the head.
Now I need to find a way of emptying the holding tank. Not easy in Barbados...
Mark
Waymar83 is offline
post #180 of 277 Old 09-30-2013
blt2ski's Avatar
You should have an emanual pump assuming where mine is on the aft side of the head wall. The Y valve is then opened to discharge overboard vs putting shyte in the tank.
That is how it is supposed to work any who.
You could also have some older hoses, after a while the hose does not contain the smells. So one needs to replace them after a period of time. For this hose, higher more expensive hose is WELL worth the extra $$$.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Jeanneau quality is fine (Jeff H) JHodor Boat Review and Purchase Forum 4 12-28-2003 01:28 AM
Jeanneau Sun Odyssey 51 Pipes Boat Review and Purchase Forum 1 09-13-2002 06:48 AM
Jeanneau Sun Odyssey 40 DS mhofmann Boat Review and Purchase Forum 1 01-03-2002 02:10 AM
Jeanneau 45 davejean Boat Review and Purchase Forum 0 08-03-2001 05:55 AM
Jeanneau Tonic 23 dpcolohan Boat Review and Purchase Forum 0 03-11-2001 04:00 AM
HTML code is Off
