Jeanneau Attalia - Page 19 - SailNet Community
 6Likes
post #181 of 277 Old 09-30-2013 Thread Starter
Not quite Senior Member
Waymar83's Avatar
Send a message via Yahoo to Waymar83
Re: Jeanneau Attalia
That's what I thought. But the y valve ( on the aft side of the head wall) seems to have some other function. I think it might link up with the manual bilge pump (also on the aft wall). One of the hoses for example ends up in the lowest part of the floor in the head, underneath the floorboard. This y valve can't be linked to the head or the holding tank.
The discharge hose from the Jabsco head seems to go straight out through the aft wall in the head and does not come back.
Oddly, I have the original owners manual and there is not a single diagram that describes any of this.
Mark
Now based in Barbados.... and wait for it.....the boat is too!
Waymar - Jeanneau, Attalia
Waymar83 is offline
post #182 of 277 Old 10-02-2013
blt2ski's Avatar
THat does not surprise me. As my boat had NEVER HAD the lines to the tank hooked up. ALways discharged straight over board. Slightly illegal for the last 10-15 yrs before I bought it!
So I had run them myself. Initially ut in a y vlave, got rid of those, straingt to the tank, then another line to the discharge via the manual pump. I have yet to use the manual pump, as I have 2 dump stations at my marina, and at least one at every marina I seem to go to here in Puget sound. Not sure why I even have the overboard part hooked up!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #183 of 277 Old 10-02-2013 Thread Starter
Waymar83's Avatar
Marty how did you do that? I've always used pump out at the marina and it was a vacuum system where they attach the hose and then it would suck everything out. It was a great marina, all I had to do was open it up and they would do the rest .
Mark
Waymar83 is offline
post #184 of 277 Old 10-04-2013
blt2ski's Avatar
Mark,
Ill be using the vacuum pump tomorrow to empty the boat before a race saturday. As I said, the previous/original owner of the boat, never put hoses into the tank. When you flushed, the head flushed overboard ALL the time. While legal back in 85, not when I bought her in 2005. So I ran lines into the tank, along with one that could pump overboard direct where legal. Eventually, I said screw that option, one never used it! So straight into the tank it goes. Have thought about disconnecting the manual overboard pump, as I will probably never be where I can dump legally overboard. So the vacuum option at various and sundry marina's is really the only option I have.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #185 of 277 Old 10-04-2013 Thread Starter
Waymar83's Avatar
I too love the vacuum pump out but can't seem to locate one in Barbados...and I don't seem to have any valves or hoses that would indicate ability to pump overboard. Which I did not care about when I was in Canada but now.... It looks like I will have to do some re engineering.
Racing Saturday! Good on you. I can't wait for the racing season to start here. Mango Bowl end of November in St-Lucia..
Mark
Waymar83 is offline
post #186 of 277 Old 10-04-2013
blt2ski's Avatar
Arcadia Headlining Replacement
Mark,
WHile it does not show the pipe routing, here is the article on the jeanneau owners site of my head redo. You can see on the back wall a slightly triangular black part. That is my manual pump to pump the tank overboard. The actual tank is behind this wall in the cockpit locker. Then it becomes a matter of getting the approx 2" hoses from the head to the tank to the pump and overboard. Or fit a Y with in the cabinet, then a pipe to the overboard valve.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #187 of 277 Old 10-11-2013 Thread Starter
Waymar83's Avatar
i think I figured out what to do. My particular model of Attalia does not have a valve with a thru hull. It ONLY goes into the holding tank and the tank can only be pumped out. I think it was finished for the Great Lakes and not for any offshore work where you can discharge. Rather than haul out and put in a thru hull with a series of valves etc, I'm going to use a an electric diaphragm pump with a 1 1)2 connector to the holding tank deck fitting with some connecting pipe and then, when I'm offshore in clement weather, I,ll hook it up and send it overboard.
Mark
Waymar83 is offline
post #188 of 277 Old 10-13-2013
blt2ski's Avatar
That could be correct. You would need a thru hull to do what I have. If you do not have one, then somethign as you describe would be your only option.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #189 of 277 Old 11-11-2013
Hi every one,
This is my first time writing on this form,
I would like to introduce myself, I am an owner of Jeanneau Attalia 1986, since 2000 and I absolutely love my boat. Through out the years I have been sailing with my boat (AKA Bettina) through the Mediterranean sea. from Israel to Cyprus, Turkey, Greece, Italy and Spain, my Bettina took anywhere safe and sound.
I am sailing with my Bettina not only for cruising but also for racing and I have more than a dozen trophies achieved over the years.
I would love to share my experiences and to learn from all Jeanneau Attalia Owners out there as a pround owner of this wonderful model
Have a safe sailing
Ido
idosachs is offline
post #190 of 277 Old 11-11-2013
JensK's Avatar
Dear Ido
Welcome here. I envy you that you have won trophies - I do a lot of racing but I am always behind.
Best regars
Jens
idosachs likes this.
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Jeanneau quality is fine (Jeff H) JHodor Boat Review and Purchase Forum 4 12-28-2003 01:28 AM
Jeanneau Sun Odyssey 51 Pipes Boat Review and Purchase Forum 1 09-13-2002 06:48 AM
Jeanneau Sun Odyssey 40 DS mhofmann Boat Review and Purchase Forum 1 01-03-2002 02:10 AM
Jeanneau 45 davejean Boat Review and Purchase Forum 0 08-03-2001 05:55 AM
Jeanneau Tonic 23 dpcolohan Boat Review and Purchase Forum 0 03-11-2001 04:00 AM
HTML code is Off
